Manjaro KDE 20.04 - cant even mount SD card after dd Manjaro from SD to emmc
After dd my working Manjaro KDE 20.04 from SD card (mounted with an SD card reader at USB) to the emmc (by booting from a 2. SD card from card slot) the pinebook pro do not boot from SD card any more. I cant even mount SD cards from the SD card slot. Any idea how to get the card slot to work again (and then with booting SD cards first, before emmc)? Thx in advance!
Addendum:
The only SD card which mount is the SD card i did the dd from - this is also the only sd card the pinebook do boot from if inserted.
  Manjaro Sway Theme Broken Eighty8 1 276 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,746 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 323 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,127 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,194 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 879 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,016 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,963 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 762 08-18-2023, 02:06 AM
Last Post: juliamenendez
