openSUSE for Pinephone
#71
(11-27-2021, 08:31 AM)flembcke Wrote: I have finally installed Posh on my pinephone.
Everything seems to work right.
Rotation is upside down, any tips on how to fix it?
Telegram can not receive the code. Any ideas how to make it work?
Do you mean you aren't receiving the SMS code from Telegram? If so, that has happened every time I set it up on the PP. I would recommend having an account on your desktop then instead of sending an SMS (which never comes through), it will send a code to the other Telegram client.
Thanks for the reply.
it does not seem much maintained ;(
I tried but autorotate turns the screen 90° to the left of what it should, and connection to nextcloud failed somehow.
Had the same issue with Telegram (on Manjaro Phosh, but it looked and did the same on Mobian or some other as well), and the point is that it's near impossible to create a new account without an old one. It just won't send the verification code as a SMS, it sends to an existing Telegram instance. So creating it with my phone didn't work, wife's didn't work (no Telegram either), daughter's did (has Telegram). But then I had her identity.
So I had to create a new account within this clone of her identity, which meant another security code. Nice touch is that this time I didn't have to retype it, the confirmation went instantaneously and I was finally me. Daughter was also me for a while... Then repeated the process for my desktop (repeated me, on Mint) and wife's laptop (also Mint, separate account). That works.
Daughter also had to do something on her Telegram to make sure she's not me and to revert to her original account.
So it won't grow from seeds, only by cloning and then identity change.
OpenSuse seems a tad more reliable with plasma mobile, compated with Manjaro, which is currently not working well. However, after update, there is not enough kernel allocated memory or it will not boot at all ;(
after flashing again it seems to work, even connected to nextcloud, but does not show any contacts. Very nice to watch boot or update in verbose.
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 38 24,995 04-23-2024, 10:29 AM
Last Post: donchurch
  PinePhone app development WhiteHexagon 15 3,906 04-23-2024, 05:19 AM
Last Post: Jonnyc
Wink PINEPHONE not booting Touchwood 2 447 02-23-2024, 07:27 AM
Last Post: Touchwood
  Slack on PinePhone Adam Seline 5 5,382 12-20-2023, 07:20 AM
Last Post: nickolas
  Struggle to install LibreOffice on the PinePhone Peter Gamma 48 24,321 11-24-2023, 07:02 AM
Last Post: Peter Gamma
  Which word processor to choose for the Pinephone? Peter Gamma 8 2,001 11-23-2023, 01:06 AM
  Using Signal on PinePhone in mid-2023? dante404 45 13,141 11-17-2023, 04:23 AM
  Genode- Sculpt OS for the PinePhone (non Linux) Surehand53 1 977 11-04-2023, 07:23 PM
  Abiword as a office mobile word processor for the Pinephone? Peter Gamma 11 2,211 10-24-2023, 08:57 AM
  What File Manager Options Are There For The Pinephone? pinephoneuser22 7 2,413 10-18-2023, 08:37 AM
Last Post: luppivega
