Manjaro - No battery info after plugged in
Just got my Pinebook, basically haven't changed anything from the stock Manjaro that came with it besides updating.
When I plug it in, the battery indicator disappears from the system tray, and the values in the Energy Consumption Statistics menu stops being updated. Even after I unplug it from the charger, the data continues to not update, and I have no way to check battery level. Battery level is set to always show in Configure System Tray. Power settings respond as expected to plugging/unplugging (screen dims when unplugged, brightens when plugged back in).
After a reboot things return to normal.
it seems that the manjaro default os has some problems with plugins, see this thread:
https://forum.pine64.org/showthread.php?...ght=upower
OK, good to know it's at least a known issue and not something I can fix on my own, so I can stop trying to solve it. Thanks.
It was a new bug in latest kde plasma 5.19, Should have been fixed by now but it will take few days to arrive at stable branch.
Manjaro ARM Team.
I am running Manjaro 20.09 on a PBP I received on Monday. The battery says 0% and thinks it will never finish charging, though it keeps running when I unplug it.
I swapped from USB-C to the barrel connector and it looks like it is charging - but it clearly wasn't at 0% before. Anyone know if Manjaro or something in the circuitry are setup to report the battery lower, if for some reason the charging info is inaccurate with USB-C charging, or if something else is the issue?
it doesn't get happy
it doesn't get sad
it just runs programs
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,747 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,134 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,204 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 884 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,017 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,965 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 764 08-18-2023, 02:06 AM
Last Post: juliamenendez
