Issues with chromium-docker
Hello There,
New to the PBP and Manjaro/arch. I am an old time enthusiast (Ubuntu, Debian, Fedora) getting back into things after about 10 years. So don't assume I know anything :-)
I have chromium and chromium-docker installed and have restarted but when I try to play a video on Amazon I still get the DRM error asking me to enable protected content playback (which it is enabled). I am unsure how to proceed to remedy this issue. Any advice would be greatly appreciated.
Thanks for taking the time.
Alright so it looks like my issues was the icon that was installed. chromium-docker requires sudo to run and the icon installed in the app tray did not contain sudo so the command kept failing and clearing before I could read it.
(06-19-2020, 10:57 AM)PVD Wrote: Alright so it looks like my issues was the icon that was installed. chromium-docker requires sudo to run and the icon installed in the app tray did not contain sudo so the command kept failing and clearing before I could read it.
How did U fix this? If  I try to run the chromuim-docker from the application launcher it closes immediately (Manjaro/Plasma)
Maybe I just don't get what this package is doing. Is it running in the background? Or acting as the browser in place of FF?
EDIT: figured it out! Happy to add more if anyone ever needs it.
If anyone else needs it, you have to add yourself to docker group
sudo usermod -aG docker $USER
Are there any tips for missing plug-ins? Generally, there is a blocking prompt in the browser URL bar.
  Issues with T-Mobile Home Internet? skinnyonthebebop 3 1,058 10-17-2023, 07:42 AM
Last Post: skinnyonthebebop
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,474 10-01-2022, 10:16 AM
Last Post: crazyquark
  MiniConda Install Issues nixyhustle 0 775 09-16-2022, 10:06 PM
Last Post: nixyhustle
  new PBP issues jpjnh 9 3,851 08-22-2022, 07:26 AM
  Issues with External Display After Recent Update reundo 0 1,362 11-18-2021, 06:37 PM
Last Post: reundo
  I have two different versions of Chromium on my Pro! Nobot 2 2,629 06-01-2021, 02:34 PM
Last Post: Nobot
  HArdware issues while charging user18130814200115 2 2,805 05-01-2021, 04:13 AM
Last Post: gabeeg
  Chromium Dino game is slow/glitchy stozi 0 1,327 04-21-2021, 08:18 AM
Last Post: stozi
  Netflix, Amazon Prime Video, and Chromium. Nobot 13 18,233 03-12-2021, 10:46 AM
Last Post: spikerguy
  App installation issues on PBP pineitup 0 1,672 10-21-2020, 06:23 PM
Last Post: pineitup
