Noisy power light.....
This morning, for the first time I can remember, the power light began flickering with noise. The noise sounds like a fluttering relay with some light beeping. I'm currently using Balena Etcher to flash an SD card. Disconnecting the AC power supply had no effect.
When Etcher finished, the noise stopped the flickering continues.....
Not aware of anything being mentiond about this particular event. Does anyone have an idea?
Many Thanks, Rick :-)
It's not noisy, it's showing disk activity.
Unless you are saying that it is continuing to flash on/off?
Arwen Evenstar
Princess of Rivendale
(06-17-2020, 08:20 AM)Arwen Wrote: It's not noisy, it's showing disk activity.
Thanks for helping!
It was odd it occurred only when using Etcher to write to an SD card.....
And being the eMMC is solid state, it never made any sounds like that before....
No big concerns about it. Thought it might be worth mentioning.
Will post anything else that happens....
  Lockable-until-power-cycle persistent storage Melab 0 715 09-17-2023, 08:51 PM
Last Post: Melab
  power on Pinebook Pro mainboard without keyboard? papable 0 835 07-20-2023, 11:06 PM
Last Post: papable
  Blinking Tiny Blue Indicator Light? ArchiMark 3 1,211 06-30-2023, 03:15 PM
Last Post: Samurai_Crow
  When does Pinebook Pro power LED go on? Bram 0 626 03-14-2023, 09:53 AM
Last Post: Bram
  Doesn’t power on after flashing emmc badguru 3 1,241 02-25-2023, 09:00 PM
Last Post: badguru
Heart Now better battery life or power management? KC9UDX 5 2,288 09-09-2022, 08:13 PM
  Replacement Power Cord recommendation? nathanielwheeler 3 3,297 01-23-2021, 06:43 PM
  [SOLVED] Red light flashes next to barrel-port Carl 31 42,617 01-18-2021, 09:34 AM
Last Post: dsimic
  power light blinking during charge when pbpro is off Idaho 0 1,800 01-04-2021, 10:53 AM
Last Post: Idaho
  Taming the power switch? ab1jx 4 4,879 11-30-2020, 10:57 PM
Last Post: rimaille
