How to root Phoenix Card images?
I used the phoenix card image from Android 5.1.1 Image Release 20160505 but it seems it's not rooted yet and the tool is not pre-installed on it.
Can you tell me how to root it?
(05-13-2016, 06:50 AM)octopus Wrote: Hi,
The only Android image on the Pine64 wiki that's rooted, far as I know, is one of the 8GB dd images. The Android image that uses PhoenixCard is not rooted.
Burning an image using dd (or Win32DiskImager) requires a different process than burning using PhoenixCard. You can't burn a dd image using PhoenixCard and you can can't use dd to burn an image meant for PhoenixCard.
It is quite simple (if you run the 0505 image of android). Just open SuperSU app and let it work its charm (installing dependencies). Do a reboot, and go get a root checker app from the store to check if it is all ok.
This worked for me Smile
FYI, I used the PhoenixCard image of android 5.1.1 build 20160505 on my Pine A64+ 2Gb
Ok but I got a 64gb sd card.
I don't have 64gb of space on my hard drive.
When you unzip the rooted images, they have the space of the sd card they are meant for.
by the way, there is no SuperSU app on the phoenix card image of android 5.1.1 20160505...
You are not ment to decompress the .img file. Just the rar file. (And that one does not take 64gb) PhoenixCard will automaticly resize the partitions on your microSD to give you all the space available in Android.
Look at the size :
[Image: 31168915052016014859.jpg]
but it's fine. I had 3x go on my hard drive.
  Is there another link for Android images? Maalth 3 7,024 10-10-2019, 07:57 AM
  Issues with SD Card and Running Android Twistedx 0 3,537 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.0 - best way to shutdown without root / button saviod 2 3,919 04-19-2018, 02:14 AM
Last Post: Harlan Mueller
  Corrupt SD Card? CaptainCWA 13 16,808 06-04-2017, 08:01 PM
Last Post: pfeerick
  Editing SD card simplexdan 2 3,999 02-25-2017, 12:09 PM
Last Post: simplexdan
  Where do we leave feedback for curated images? howardsternisbatman 0 2,248 01-26-2017, 03:18 PM
Last Post: howardsternisbatman
  android image & sd card size problems tomarneson 11 17,682 01-24-2017, 05:31 AM
Last Post: ayufan
  Creating bootable SD card on Mac OS X colinj 13 20,254 01-24-2017, 03:03 AM
Last Post: MarkHaysHarris777
  SD card too small Error loungehound 7 12,619 01-21-2017, 05:37 PM
Last Post: Bluphire
  Tutorial: How to create DD images with appropriate size tkaiser 5 12,402 12-20-2016, 08:17 AM
Last Post: Bluphire
