pinebook pro tools
#21
updated some dependencies. added emmc and wireless reset scripts.
I can't seem to get the linux script to build a rc. How do I set the vars?
LINUXBASE=5.8 LINUXPATCH=5.8-rc3 ./pbp-build-linux
you can now also set a PBPTOOLSDIR env variable in .bash_profile or export and add to your path:
export PBPTOOLSDIR=~/Development/pbp-tools
export PATH=$PBPTOOLSDIR:$PATH
see the example in resources/bash/bash_profile
then you can run from any directory in terminal:
LINUXBASE=5.8 LINUXPATCH=5.8-rc3 pbp-build-linux
also adapting all scripts to use INSTALLDEPS=debian. if you would like to help with your own distro deps LMK.
i have also uploaded my own 5.7.3 and 5.8-rc3 deb packages to the debian-packages git repo. in the future i plan to make a proper debian repo.
(07-02-2020, 09:20 AM)xmixahlx Wrote: LINUXBASE=5.8 LINUXPATCH=5.8-rc3 ./pbp-build-linux
Thanks again!
fyi building 5.8-rc4 also works, just update the LINUXPATCH var.
i've also added cpupower config and info scripts, and nvme and upower info scripts.
for pbp-config-cpupower, you can set the profile at commandline, i.e. PROFILE=performance or run without profile variable set to select governor for big and little cpus, and min and max frequencies for both little and big cpus.
pbp-info-cpupower displays current governor and frequency status.
pbp-info-upower displays current battery status.
pbp-info-nvme collects and logs features and capabilities of the nvme drive, and tests with hdparm.
linux 5.8-rc5 and ffmpeg 4.3.1 working well. updated defaults in scripts.
note that linux 5.7.5+ not building due to patch conflict and is low on my list to fix. i recommend 5.8--rc5.
also added nvme-ps and system (power, vm) config scripts.
I installed Daniel T's debian on my microSD with sid and ran.
DEBRELEASE=sid HWACCEL=yes WAYLAND=yes XFCE=no ./pbp-install-desktop
I rebooted my machine then ran:
LINUXBASE=5.8 LINUXPATCH=5.8-rc5 ./pbp-install-linux
I installed the 3 deb files and rebooted.
After that, just a black screen after waiting over 10 minutes.
Any advice to get this working?
it is probably maxcpus=4 in u-boot config -- 5.7+ kernels dont use that config anymore. change in extlinux, if that works change your /etc/default/u-boot ref.
there are several other changes in the installer for 5.7+. see my fork on git for details.
you should also install the hwaccel kernel first if you are installing any other hwaccel packages.
I removed maxcpus from extlinux.conf and it still didn't work. I installed it after cloning your Git repo less than 24 hours ago.
Here's the new entry that have in my file:
default l0
menu title U-Boot menu
prompt 0
timeout 10
label l0
menu label Debian GNU/Linux kernel 5.8.0-rc5-0.40-1-pinebookpro-hwaccels
linux /vmlinuz-5.8.0-rc5-0.40-1-pinebookpro-hwaccel
initrd /initrd.img-5.8.0-rc5-0.40-1-pinebookpro-hwaccel
fdt /rk3399-pinebook-pro.dtb
append root=PARTLABEL=microSD-RootFS console=ttyS2,1500000n8 console=tty0 ro quiet splash plymouth.ignore-serial-consoles coherent_pool=1M
I am using my PBP laptop without any external devices, except for the microSD card that I'm booting from. Do you have any other suggestions?
(07-19-2020, 10:41 AM)charlespine Wrote: I removed maxcpus from extlinux.conf and it still didn't work. I installed it after cloning your Git repo less than 24 hours ago.
default l0
prompt 0
timeout 10
label l0
I compiled 5.7.4 and it's working Smile I guess I'll wait until the non-rc 5.8 comes out.
  Debian on Pinebook Pro u974615 7 840 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,455 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,080 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,161 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,030 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,177 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,160 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,452 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,530 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 647 07-13-2023, 05:21 PM
Last Post: owaspfap
