Bigger batteries for the Pinephone?
I found here : https://www.youtube.com/watch?v=zaNzPooIWsU&t=76s the information, that the batteries of the Pinephone can be replaced by bigger ones. In the Pinephone Wiki there is the information, that the Pinophone batteries have the form-factor of Samsung J7 batteries. For some smartphones there are bigger batteries available, but for Samsung J7 batteries I could not find bigger ones. Are any bigger batteries available for the Pinephone?
Somewhere recently, I think it was Luke, who mentioned they were considering a larger battery, requiring a new back cover.
Most likely he will cover that when he posts his "June Update"
Otherwise, there are some older posts discussing higher rated batteries that are the same physical size.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(06-09-2020, 02:08 PM)Peter Gamma Wrote: I found here : https://www.youtube.com/watch?v=zaNzPooIWsU&t=76s the information, that the batteries of the Pinephone can be replaced by bigger ones. In the Pinephone Wiki there is the information, that the Pinophone batteries have the form-factor of Samsung J7 batteries. For some smartphones there are bigger batteries available, but for Samsung J7 batteries I could not find bigger ones. Are any bigger batteries available for the Pinephone?
Luke mentions "A large (5000mAh) battery case for the PinePhone is being explored" in the last update; found here: https://www.pine64.org/2020/05/15/may-up...ging-more/
Also, read through the comments, as he discusses that a bit further.
Thank you both for your answers. I found in the forum a thread about 3300 mAh batteries instead of 3000 mAh, but is it worth it?
Thank your for the link with the discussion, which I already joined.
I m investigating a setup for sensor data aquisition with a Pinephone which runs 24 h 7 d, and a bigger battery option would be highly desirable.
As long as there is a problem to get a large battery, say more than 5000 mAH:
https://www.pine64.org/2020/05/15/may-up...94#respond
a DIY option would be to take apart a Samsung J7 battery and add an usb connector for an external power bank.
  Case for Pinephone totilele 13 7,222 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 635 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,165 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 449 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 514 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 1,021 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,297 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 5,026 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 37,381 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 634 08-04-2023, 10:47 PM
Last Post: jnpine
