Audio jack and external mic?
Will the headset jack on the PBP work with combined mic/headsets? The wiki seems to say it should, but so far it doesn't for me. Using Manjaro, have tried two different headsets which work on other machines. Headset function works, but mic does not. The mic privacy switch is set to enabled, and the built-in mics are working (with the reported whine, of course). USB mic also works.
-john
(06-08-2020, 12:18 PM)johns Wrote: Will the headset jack on the PBP work with combined mic/headsets? The wiki seems to say it should, but so far it doesn't for me. Using Manjaro, have tried two different headsets which work on other machines. Headset function works, but mic does not. The mic privacy switch is set to enabled, and the built-in mics are working (with the reported whine, of course). USB mic also works.
-john
You likely need to change the input port within your system sound settings.
The privacy switches only disable the internal mics, IIRC, and should not effect any external mics.
-john
That makes sense, but the system sound settings don't show the headset mic as an option. Whereas, if I connect a USB webcam with a mic, that does show up as an input device.
-john
You might want to look at the settings in ALSA, then: https://linuxconfig.org/how-to-test-micr...cture-alsa
(06-08-2020, 02:59 PM)tophneal Wrote: You might want to look at the settings in ALSA, then: https://linuxconfig.org/how-to-test-micr...cture-alsa
Okay. I guess I'm confused about how ALSA and PulseAudio might interact here. pavucontrol seems to provide accurate controls for my other input and output devices, just not the headset mic.
On another system, where the headset mic works, it shows up as a selectable input device in pavucontrol (something like "headset microphone (plugged in)")
Thanks for the ALSA test link. I tried it, but arecord -l only shows a single device with the headset plugged in.
**** List of CAPTURE Hardware Devices ****
card 0: rockchipes8316c [rockchip,es8316-codec], device 0: ff890000.i2s-ES8316 HiFi ES8316 HiFi-0 [ff890000.i2s-ES8316 HiFi ES8316 HiFi-0]
Subdevices: 0/1
Subdevice #0: subdevice #0
Attempting to record on that device (which I assume is the built-in mic anyway) gives an error:
arecord -f S16_LE -d 10 -r 16000 --device="hw:0,0" /tmp/test-mic.wav
arecord: main:830: audio open error: Device or resource busy
which is odd because nothing is using the input device (and both the toolbar audio mixer and pavucontrol show no active input).
Any ideas about next things to try? Are we sure that this should work to begin with?
-john
Have you run across this wiki section yet? https://wiki.pine64.org/index.php/Pinebo...icrophones
I tried to pull out some old iPhone headphones that have the microphones, but it turns out they are trash, and I have no other 3.5mm headphones. :/
  Got a PBP - batch(August/September) and the audio is not good(2 big issues) crazyquark 2 1,400 10-01-2022, 10:16 AM
Last Post: crazyquark
  No audio from HDMI with usb-c adapter rfm83 5 2,885 06-19-2022, 09:06 PM
Last Post: rfm83
  Issues with External Display After Recent Update reundo 0 1,337 11-18-2021, 06:37 PM
Last Post: reundo
  External Monitor resolution (would like 3840x2160) Phillip Bell 3 2,113 11-17-2021, 10:02 AM
Last Post: Phillip Bell
  Workaround for crackling audio when music starts/stops pato3 1 2,478 07-28-2021, 12:26 PM
Last Post: dsimic
  alsamixer and audio scale settings- how to make persistent straightwalker 0 1,439 06-04-2021, 10:57 AM
Last Post: straightwalker
  External DVD/CD MIchael 22 21,606 03-07-2021, 03:49 PM
Last Post: ab1jx
  External Monitor Recommendations SteveSquatch 1 1,747 02-17-2021, 08:23 AM
Last Post: Arwen
  Audio with Debian GloriousCoffee 5 7,171 10-15-2020, 01:22 PM
Last Post: Mangled
  [split] Change password from external media James Good 11 12,568 07-23-2020, 02:42 PM
