Nvme drive not being recognised.
Hi all, I added a KingSpec NE-512 NVMe drive, listed as compatible in the PBP HW accessory wiki to my PBP however it is not being recognised either with the stock Debian+Mate (on eMMC) or latest Manjaro XFCE edition (on SD).  Have flashed pcm720's uboot to eMMC and SD without effect.
I just want to use it as a data drive, at least to start with and was hoping it would just work.[url=https://wiki.pine64.org/index.php/Pinebook_Pro_Hardware_Accessory_Compatibility][/url]
Do I need to update the uboot on SPI?  Which uboot release (the one by 720pcm or sigmaris)? And which procedure (the one using rkdeveloptool or the one dd'ing to /dev/mtd0?)
All feedback welcome, thank you.
Vidya
#lspci -vvv
#dmesg | grep -i pci
[    0.004174] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    3.638913] PCI: CLS 0 bytes, default 64
[   28.899325] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[   29.988256] ehci-pci: EHCI PCI platform driver
[   30.198563] ohci-pci: OHCI PCI platform driver
[   32.410343] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[   32.990231] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[   32.991341] rockchip-pcie: probe of f8000000.pcie failed with error -110
#lsblk
NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
mmcblk2      179:0    0 116.5G  0 disk
├─mmcblk2p1  179:1    0    64M  0 part
└─mmcblk2p2  179:2    0 116.4G  0 part
mmcblk2boot0 179:32   0     4M  1 disk
mmcblk2boot1 179:64   0     4M  1 disk
mmcblk1      179:96   0  59.5G  0 disk
├─mmcblk1p1  179:97   0 213.6M  0 part /boot
└─mmcblk1p2  179:98   0  59.2G  0 part /
#nvme list
Node             SN                   Model                                    Namespace Usage                      Format           FW Rev
#cat /proc/version
Linux version 5.6.0-2-MANJARO-ARM (strit@on2-distcc) (gcc version 9.2.0 (GCC)) #1 SMP Thu Apr 2 21:13:13 CEST 2020
use mrfixit's v2.0 uboot. replace your uboot however it is working now.
(06-07-2020, 05:02 PM)xmixahlx Wrote: use mrfixit's v2.0 uboot. replace your uboot however it is working now.
Thanks,  is there a link ?  Ideally to the binaries.
(06-08-2020, 06:24 AM)vssz Wrote: Thanks,  is there a link ?  Ideally to the binaries.
There is a link on the main wiki page for the PBP, there's also a link for pcm720's uboot, whihc is based on mrfixit's.
mrfixit accepted pcm's pulls so v2.0 includes them.
OK, the PCM720 uboot I already tried (from here as mentioned in his forum post here with both stock Debian (eMMC) & Manajaro XFCE (SD)) but I cannot find the other link mentioned off the main wiki page?  Any idea?  Thanks a lot!
(06-08-2020, 10:30 AM)vssz Wrote: OK, the PCM720 uboot I already tried (from here as mentioned in his forum post here with both stock Debian (eMMC) & Manajaro XFCE (SD)) but I cannot find the other link mentioned off the main wiki page?  Any idea?  Thanks a lot!
mrfixit's v2.0 uboot files can be found here: https://github.com/mrfixit2001/updates_r...filesystem
Ok, tried MrFixit's uboot (on SD with latest Manjaro that definitely has pcie support) but unfortunately the same result.
Mine is a 1st batch PBP if that's of any significance.
Any suggestions?
Thanks in advance.
[    0.004232] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.261972] PCI: CLS 0 bytes, default 64
[    1.174188] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    1.205991] ehci-pci: EHCI PCI platform driver
[    1.265661] ohci-pci: OHCI PCI platform driver
[    1.744198] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    2.324372] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.325559] rockchip-pcie: probe of f8000000.pcie failed with error -110
#lsblk
sda            8:0    1    57G  0 disk
└─sda1         8:1    1    57G  0 part /run/media/vssz/Transcend
mmcblk1      179:96   0  58.2G  0 disk
└─mmcblk1p2  179:98   0    58G  0 part /
#lspci -vvv
#nvme list
#cat /proc/version
#zgrep -i pcie /proc/config.gz |grep -v '^#' | more
CONFIG_CAN_PEAK_PCIEC=y
CONFIG_PCIEPORTBUS=y
CONFIG_HOTPLUG_PCI_PCIE=y
CONFIG_PCIEAER=y
CONFIG_PCIEAER_INJECT=m
CONFIG_PCIE_ECRC=y
CONFIG_PCIEASPM=y
CONFIG_PCIEASPM_DEFAULT=y
CONFIG_PCIE_PME=y
CONFIG_PCIE_ROCKCHIP=y
CONFIG_PCIE_ROCKCHIP_HOST=y
CONFIG_PCIE_DW=y
CONFIG_PCIE_DW_HOST=y
CONFIG_PCIE_DW_PLAT=y
CONFIG_PCIE_DW_PLAT_HOST=y
CONFIG_BRCMFMAC_PCIE=y
CONFIG_MWIFIEX_PCIE=m
CONFIG_QTNFMAC_PCIE=m
CONFIG_DVB_SMIPCIE=m
CONFIG_PHY_ROCKCHIP_PCIE=y
confirm nvme and not sata
reseat nvme adapter cable
reseat ssd
focus on basic detection by kernel
>>see for yourself here on aliexpress and also listed compatible in the PBP Wiki (KingSpec NE-512).
>>done many times
reseat ssd
>>ditto
>>Tried with my stock Debian and 5.6/5.7 Manajaro kernels. Any particular suggestion?
Ordered another PBP nvme adapter as the first version which I received needs 2 folds of the ribbon cable which might be the problem  Huh  and also an M.2 NVMe SSD enclosure to verify the SSD.  Hoping between these 2 the issue is further isolated.
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 705 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 751 07-13-2023, 01:50 PM
Last Post: PaulQ
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,384 04-23-2023, 06:58 AM
Last Post: acruhl
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 212,229 09-27-2022, 07:41 AM
Last Post: olyavi
  Selling Pinebook Pro (ISO) + nvme from Sweden DavidL 5 3,063 06-20-2022, 03:20 PM
Last Post: DavidL
  For Sale: Pinebook Pro 64gb ANSI with NVMe Adapter Lumat 2 1,990 04-24-2022, 01:42 AM
Last Post: kylexd
  Selling PineBook PRO with ISO Keyboard + NVME firefox-58 27 17,847 04-08-2022, 06:23 AM
Last Post: firefox-58
  Pinebook Pro (ANSI) with NVME 1TB (660p) for sale Fish 5 3,933 01-26-2022, 08:49 AM
Last Post: TRS-80
  Selling PineBook PRO with ANSI Keyboard + NVME woodeen 3 3,038 11-30-2021, 06:38 PM
Last Post: luca22
  Boot from NVME theboz1@verizon.net 2 2,311 10-22-2021, 07:58 PM
Last Post: theboz1@verizon.net
