PBP won't start
Sad
I got my PBP yesterday and could use it for a day. Even serial console via UART worked.
Now, I cannot turn it back on. I pressed power button for 20 seconds, nothing happens, LCD stays black, no LEDs flash, no output on the serial console via UART.
I tried with SD card inserted and without, no difference.
What can I do now?
Cheers
woschtsuppe
Can be closed, somehow after some hours of doing nothing the thing suddenly boots again
are you sure it is charged? plugin via barrel adapter, wait 10min and try again.
otherwise it is usually a problem with uboot, or the boot partition
  No start button light gilwood 6 502 02-09-2024, 08:31 AM
Last Post: gilwood
  PBP solid orange light and does not start Disjoin8272 1 1,074 02-18-2023, 02:46 AM
