Can't connect to wifi
Hello, I just received my Pinebook Pro last night. I ran the initial setup and connected to wifi just fine. Then I updated and rebooted and I haven't been able to connect to wifi since. It seems to stall out at "Setting network address". I have tried deleting the configuration and starting over from scratch, manually entering in the MAC address that was stored in the router in case there was a mismatch somewhere, specifically changing the BSSID to both 2.4 and 5 GHz connections, and restarting the NetworkManager service as well as many reboots sprinkled in throughout and nothing seems to change. This is on the stock Manjaro out of the box, I haven't changed anything other than update.
Any help is appreciated.
(06-04-2020, 09:24 AM)malachipclover Wrote: Hello, I just received my Pinebook Pro last night. I ran the initial setup and connected to wifi just fine. Then I updated and rebooted and I haven't been able to connect to wifi since. It seems to stall out at "Setting network address". I have tried deleting the configuration and starting over from scratch, manually entering in the MAC address that was stored in the router in case there was a mismatch somewhere, specifically changing the BSSID to both 2.4 and 5 GHz connections, and restarting the NetworkManager service as well as many reboots sprinkled in throughout and nothing seems to change. This is on the stock Manjaro out of the box, I haven't changed anything other than update.
Have you enabled WIFI via the privacy switch?
https://wiki.pine64.org/index.php/Pinebo...y_Switches
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 861 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 3,980 07-15-2023, 02:58 PM
Last Post: u974615
  5GHz wifi not working snorwood 11 5,497 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 1,293 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 2,580 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 4,583 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,354 08-25-2022, 02:15 PM
Last Post: Niko
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 2 2,967 04-12-2022, 02:36 PM
Last Post: cobratbq
  Pinebook Pro wifi not working seyo-iv 2 3,754 10-26-2021, 02:27 AM
Last Post: wangyukunshan
  Sporadic Wifi initialization issue xyzzy 0 1,845 11-20-2020, 03:16 PM
Last Post: xyzzy
