USB-C Dock with HDMI no output
Using a USB-C dock with a new pinebook. The other ports on the hub function. However there is no HDMI output.
When examining the "display configuration" GUI window (KDE) there is a second window called "DP-1" when the dock is plugged in, irregardless of whether a HDMI is plugged in or not.
When inserting the USB-C cable the other way around, the Display Configuration does not show any extra monitors irregardless of HDMI. It does not display the "DP-1" window in this case either.
HDMI on the USB-C dock works when connected to other devices
I updated Manjaro and HDMI is also stopped working for me.
It was working before the update.
I also have no sound via USB-C to HDMI adapter to my TV. Haven't looked much into it yet since I can just plug my speaker system via headphone jack
  Broken usb-c to hdmi with kernel 5.18+ rfm83 6 2,821 01-22-2023, 09:55 PM
Last Post: rfm83
  No audio from HDMI with usb-c adapter rfm83 5 3,066 06-19-2022, 09:06 PM
Last Post: rfm83
  pinebook pro dock display out mamboman777 0 1,496 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 3,030 07-19-2021, 04:00 PM
Last Post: jbrock
  USB Dock Flashes When Connected carlosqueso 1 2,758 06-19-2020, 03:48 PM
Last Post: carlosqueso
  HDMI GloriousCoffee 30 30,347 04-14-2020, 08:07 AM
Last Post: Arwen
  USBC -> HDMI Success! mamboman777 0 1,809 01-21-2020, 09:16 PM
