Android 6.0 Tablet and TV (release candidate, maintained)
Based on my work for Android 7.0 (http://forum.pine64.org/showthread.php?tid=2136) I did downgrade to 6.0.
Download: https://github.com/ayufan-pine64/android-6.0/releases
It takes about 10 minutes for first boot to finish.
Report all issues here: https://github.com/ayufan-pine64/android-6.0/issues
What does work?
It seems to work nicely and be more responsive then 7.0 build.
Widevine DRM L3 does work, so you should be able to use Netflix.
It also allows you to update SuperSU binary, so rooting is OK too.
What does not?
- So far it seems to be OK.
This is alpha build, so do not complain Smile
If something doesn't work:
- try to see logs (adb logcat, adb shell dmesg),
- try to compile and fix it by yourself,
- when you find solution create a Pull Request for one of this repositories: https://github.com/ayufan-pine64/
How to compile?
https://github.com/ayufan-pine64/local_m...arshmallow
You can also see my Jenkins compilation script:
https://github.com/ayufan-pine64/android...enkinsfile
Download:
Install:
The builds are designed to be used with Pine A64 1GB or 2GB on at least 4GB sdcard.
Use Etcher to write images: https://www.etcher.io/
The build automatically resize data partition on first boot to use sdcard space.
LCD:
To enable LCD, edit uEnv.txt from BOOT partition and uncomment:
pine64_lcd=on
HDMI resolution:
Edit uEnv.txt and select one. You can find all supported in uEnv.txt:
disp_mode=1080p60
Ethernet speed:
Edit uEnv.txt and select desired speed, by default it uses auto-negotiation.
For example to limit to 100Mbps:
eth0_speed=100
Google Apps:
Android Regular and TV already has Google Apps installed.
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
So which version are you try to make as primary? Which one will you try to make the most stable version?
PS. pozdro z wawki  Wink
Regards,
Patryk
(11-26-2016, 05:21 AM)neyron Wrote: Hi,
Regards,
Patryk
Not answering your question as its not directed at me, but from what I've heard from ayufan droid 6.0 runs really nicely on the pine.
Pozdrowienia z Londynu
i am useing TV build app i use are work Crunchyroll TV (not working on 7.0 & 7.1)
Android remote system is not working
Android Remote TV is not working as apk is not installed on this version yet.
For me it seems that 6.0 has the best possibility of becoming stable release as uses AV codecs compatible with 6.0.
Releases:
Buy me a Beer
first off, great work, haven't really come across any issues.
except.... when I search for netflix in the play store I am not able to find it. I live in the US if that matters.
will downloading the apk be the only way to get it on?
mhump711: yes, you have to sideload Netflix
Releases:
Buy me a Beer
Works really nice. Only I have recognized that H.265 streams are not working with Kodi (I have only tested TV version). It was working with Android 7 release.  Seems that Kodi can not identify GPU.
wappi: maybe that it uses NuPlayer by default, not AwPlayer.
Releases:
Buy me a Beer
on 0.3.0: jenkins-android-6.0-pine-a64-13 i can see gpu info on Kodi
(11-28-2016, 01:02 PM)wappi Wrote: Works really nice. Only I have recognized that H.265 streams are not working with Kodi (I have only tested TV version). It was working with Android 7 release.  Seems that Kodi can not identify GPU.
Shocked Remote for Android? liodra 18 29,151 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,520 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,863 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 6,931 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,518 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,291 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 253,733 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,492 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 103,762 02-10-2019, 07:44 PM
Last Post: mmmarcus
  +LTS/SOPINE Android SDK support and Customization biplab777 1 4,602 01-07-2019, 01:21 AM
