Best location for adhesive wifi antennas with NAS case
(02-17-2020, 05:49 AM)callegar Wrote: Hi, I have just received my NAS case. Even if I do not need it now, in the future I'd like to have wifi support, so I have also bought the wifi module.
- Is it possible to use WIFI with the supplied adhesive antennas (at short range) or do you always need external antennas with the metal case?
- If it is possible to use the supplied adhesive antennas, how would you fit them in the NAS case? Not sticking them? Sticking them to what?
Thanks!
Better using external rubber antenna. You can use the supply antenna and just don't stick to NAS metal case.
RE: Best location for adhesive wifi antennas with NAS case - by tllim - 02-17-2020, 12:40 PM
  AW-CM256SM wifi card mtek 4 2,307 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 12,721 10-17-2022, 04:43 AM
Last Post: callegar
  Pine Wifi Module williamdieter 2 2,734 07-20-2022, 03:31 AM
Last Post: imianz
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,889 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 1,420 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 2,249 12-04-2021, 05:14 AM
Last Post: Goffi
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,568 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,280 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 4,985 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 1,717 01-09-2021, 05:24 PM
Last Post: kuleszdl
