Quiet Speakers In Manjaro
(03-27-2020, 11:07 AM)MrDitchy Wrote: I found a temporary fix on the manjaro forum. Open a terminal and type alsamixer, then press f6 and choose the "0 rockchip,es8316-codec" option then using the up/down/left/right keys move your volume into the white area(the red can damage the speakers) in the lefthand headphone column. then exit. I don't know how to save the setting, I tried "sudo alsactl store" but that didn't work. So you need to do this every time you want to listen to anything
That works great! Now the only issue I have is distortion on my right speaker if I get relatively close to fully volume. Thanks for the tip!
Quiet Speakers In Manjaro - by TDC_PBP - 02-09-2020, 03:23 PM
RE: Quiet Speakers In Manjaro - by mamboman777 - 02-14-2020, 05:53 AM
RE: Quiet Speakers In Manjaro - by gabeeg - 02-14-2020, 12:55 PM
RE: Quiet Speakers In Manjaro - by MrDitchy - 03-27-2020, 11:07 AM
RE: Quiet Speakers In Manjaro - by TDC_PBP - 04-16-2020, 07:29 AM
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,747 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,133 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,204 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 884 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,017 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,964 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 764 08-18-2023, 02:06 AM
Last Post: juliamenendez
