RockPro64 getting started - non-booting images [solved]
(03-05-2020, 03:58 PM)grukrz2 Wrote:
(11-21-2019, 01:09 AM)new-rockpro-user Wrote: Well, even with all that, it continues to be a little hit or miss.
Manjaro booted exactly once from eMMC. And reflashing the eMMC appears to make no difference.
It does seem to boot more reliably from SD though. So there's that.
Any extra ideas or pointers about booting non-ayufan images from eMMC would be welcome!
I've flashed U-Boot on my RockPro64 using your procedure but I don't see U-Boot starting from SPI memory when I power system on.
On eMMC I have installed Libreelec which boots fine (without jumper).
Microsd with Debian I can only boot when I plug-in jumper (=disable eMMC)
Knowing that SPI is flashed properly (as on output linked above), how could I boot from microsd without necessity inserting jumper.
According to https://github.com/ayufan-rock64/linux-b...ash-spi.md I should have possibility booting with order:
  1. SPI flash
  2. eMMC (disable with jumper)
  3. microSD
  4. USB drive
  5. PXE
I seems to be about as far into booting the RockPro64 as you are.
As far as I understand it, even with the uboot in the spi, if you add an eMMC with a bootable image, it will always boot from there first.
So, no matter if you add a microSD or USB drive, it will still boot eMMC. Unless you jumper it.
Which, to be honest, seems to be a very unfortunate design decision.
Basically, with the RockPro64, the eMMC is useless if you are experimenting one way or another with different images.
Especially if you use a case like the official premium aluminum case, you can only use the SD card to boot if you don't have an eMMC plugged in.
I could boot almost nothing at first, and this only improved when adding the ayufan spi. But that brings the above situation.
My eMMC is collecting dust now. Also, I only got booting from USB working with USB 2.
Also, not sure why, but the red light stays on quite long before actually commencing the booting. And sometimes requiring an extra reset to go.
So, basically, what I'm saying, the booting situation here is pretty horrible. But, then, when it boots, the RockPro64 is actually quite nice.
We seem to be missing some kind of boot menu, a la petitboot, grub or whatever.
RE: RockPro64 getting started - non-booting images [solved] - by new-rockpro-user - 03-06-2020, 06:31 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 345 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 650 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,523 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 16,843 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 82,231 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 542 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 880 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 1,489 01-13-2023, 06:21 PM
Last Post: misterc
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,588 01-03-2023, 06:53 PM
Last Post: raph
  hello i want to drive an edp screen with my rockpro64 hannescam 0 707 10-20-2022, 01:22 PM
Last Post: hannescam
