PINE64 to allow use of SATA disk on network/FTP
(11-12-2019, 01:26 AM)mwelbourne Wrote: Hi. I'm looking for a low cost way of being able to access an 2TB SATA drive across my home network and hopefully the internet. I was looking at using a Raspberry Pi but someone has suggested using a PINE64 because it should be easier to connect the drive. I'm totally new to PINE64, I'd not heard of it until a few days ago.
The drive won't ever be accessed that often, it just seems like a better solution with more access that just having inside a PC.
So, my current thinking is to get a PINE64, probably the 2GB verison, a decent SD card, install openmedia vault, attach the drive to the board and connect the board to my wifi router.
Does this sound like a good plan?
If I'm attaching a SATA drive then I think I can't use and enclosed case?
The Rock64 isn't much more and has USB3 and a bit faster and what not, and it's the same form factor as the rpi3B so plenty of case options available. The only board with a sata option is the rockpro64 and the PCIe sata board.
In any case emmc is faster and I'd do that rather than sdcard...
RE: PINE64 to allow use of SATA disk on network/FTP - by evilbunny - 11-12-2019, 01:57 AM
  Pine64 as squeezebox touch replacement Learnincurve 12 27,938 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 9,580 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 3,964 08-06-2020, 12:05 AM
Last Post: tuaris
Information Pine64 Head Unit Zoidiano0 100 142,114 11-19-2019, 04:35 AM
Last Post: rogatip79
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 42,606 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 3,538 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 37,966 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 9,659 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 7,120 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 6,041 01-18-2018, 05:51 AM
Last Post: Luke
