Anyone tried the new mainline images (Panfrost)?
https://github.com/ayufan-rock64/linux-m...118-ayufan
Has Panfrost compiled!! HDMI audio & PCIe!! Ayufan at his industrious usual.
Seems to sit well with https://github.com/ayufan-rock64/linux-b.../tag/0.9.4
As a test I install the tasksel version of kde-plasma and its rather great with the above 2.
You need to set the network renderer to NatworkManager in the netplan yaml
Also just a slight one but the symlink in /etc/alternatives sets the sddm greeter to moai whilst all the rest is breeze so you might want to change that.
sudo apt-get install sddm-theme-breeze
I have tried gnome and its ok vanila but soon as you theme it, then it starts to get a bit clunky.
Its all opinion though, but think I waiver to criticism than optimism so suggest giving kde-plasma a go.
Burn the image, boot and sudo tasksel and select kde-plasma.
Presuming LXQT will be even more snappy.
I used dd to copy to my integral 120gb £20 nvme and apart from a slow boot in operation its extremely good.
The dts is
&pcie0 {
ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>;
num-lanes = <4>;
pinctrl-names = "default";
pinctrl-0 = <&pcie_perst>;
vpcie12v-supply = <&vcc12v_dcin>;
vpcie3v3-supply = <&vcc3v3_pcie>;
status = "okay";
   So I did a quick bodge and cross compiled on my pc and inserted after num-lanes = <4>;
max-link-speed = <2>;
So it acts a pcie gen 2.0 otherwise you get 1.0
Anyone tried the new mainline images (Panfrost)? - by stuartiannaylor - 08-13-2019, 07:04 AM
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,372 08-16-2023, 01:34 AM
Last Post: varac
  Armbian images available Luke 60 87,352 08-04-2022, 06:56 AM
Last Post: Rocklobster
  Compiling ayufan mainline - DT-overlay missing Mentaluproar 0 1,458 07-24-2021, 09:46 PM
Last Post: Mentaluproar
Question Mainline Debian Buster on RockPro64 ? chrestomanci 36 35,934 02-14-2021, 02:37 PM
Last Post: foresto
Thumbs Up First Manjaro Mainline build! Luke 10 15,835 10-20-2020, 04:29 AM
Last Post: vfr400racer
  Rockpro64 panfrost installation questions user12321 2 4,561 05-27-2020, 10:17 AM
Last Post: xmixahlx
  Mainline U-Boot with Arch Linux PKGBUILD mmatyas 0 2,046 04-17-2020, 03:49 AM
Last Post: mmatyas
  Slow/dead ethernet on (non-Ayufan) Linux Mainline (fixed) mmatyas 1 3,543 04-17-2020, 02:53 AM
Last Post: Thra11
  RockPro64 getting started - non-booting images [solved] new-rockpro-user 3 6,105 03-06-2020, 06:31 AM
Last Post: new-rockpro-user
  Mainline Kernel 5.4 Solution khaosgrille 1 3,419 01-05-2020, 12:57 PM
Last Post: khaosgrille
