Cannot flash android 9 rockchip tool
First i want to thank you for building Android Pie for the rock64  Big Grin .
I just saw it, and i wanted to install it, but i'm facing a issue i downloaded the file from this section :
[Image: n0tezRL.png]
I installed the driver successfully and the rock64 is reconized i follow all the step frop the ayufan guide :
http://files.pine64.org/doc/rock64/guide...o_eMMC.pdf
but i'm stuck after "Download Firmware 100%", the next step is "checking : failed" then, the rock64 doesn't reboot and if i do it have a android logo with a Error.
I tried 3 time with different usb port, after a reboot but, no luck yet, what's wrong ?
Thank you
Cannot flash android 9 rockchip tool - by totalgaara - 06-22-2019, 03:47 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,219 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,010 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,534 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,179 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,001 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,479 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,983 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,566 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,702 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,759 09-09-2020, 08:44 AM
Last Post: BowerR64
