NAS case testing with Armbian_5.88_Rockpro64_Ubuntu_bionic_default_4.4.180_desktop
Note: tests (1) to (5) with CPU Fan control set at 127 with open NAS case. SATA card from Pine64.
(1) Creating a 40GB file on SATA drive
WR Red 4TB
root@rkpro64:~# dd if=/dev/zero of=/mnt/hda/40gb.txt bs=4096 count=10485760
10485760+0 records in
10485760+0 records out
42949672960 bytes (43 GB, 40 GiB) copied, 237.795 s, 181 MB/s
WD Black 4TB
root@rkpro64:~# dd if=/dev/zero of=/mnt/hd1/40gb.txt bs=4096 count=10485760
42949672960 bytes (43 GB, 40 GiB) copied, 198.201 s, 217 MB/s
HGST He 10TB
42949672960 bytes (43 GB, 40 GiB) copied, 173.657 s, 247 MB/s
So the WR Red 4TB is not too surprisingly the slowest, it's also the cheapest and consumes much less power and runs quite "cold" compared to the others (for this last thing, I did not measure it, I just touch the disk). It's 5400rpm vs 7200rpm anyway. Otherwise the HGST basically leaves the WD black in the dust.
(2) Both at the same time (hd1 = WD Black on SATA port 3, hd2 = HGST on SATA port 4)
42949672960 bytes (43 GB, 40 GiB) copied, 208.836 s, 206 MB/s
root@rkpro64:~# dd if=/dev/zero of=/mnt/hd2/40gb.txt bs=4096 count=10485760
42949672960 bytes (43 GB, 40 GiB) copied, 255.631 s, 168 MB/s
So, if you write on both drives at the same time port 2 comes... well, second.
(3) Copying each file other one after one (hd1 = HGST on SATA port 3, hd2 = WD Black on SATA port 4)
root@rkpro64:~# time cp /mnt/hd1/40gb.txt /mnt/hd2/40gb-1.txt
real    3m56.745s
user    0m0.368s
sys    2m49.948s
root@rkpro64:/var/log# time cp /mnt/hd2/40gb.txt /mnt/hd1/40gb-1.txt
real    3m40.534s
user    0m0.392s
sys    2m45.976s
(4) NAS case (still open), testing power consumption (n.nnA) and temperature (nnC), no disks attached:
- Average 1.06A when system is idle with CPU Fan control set at 127 (a little bit noisy)
- Average 1.12A when system is idle with CPU Fan control set at 255 (very noisy)
(5) NAS case (still open)
- With one WD Red 4TG plugged-in, writing 40GB file (zeroes): 1.28 to 1.41A
- Burst to 2.2A at boot for less than a second with two WD Red 4TB
- With two WD Red 4TB, writing 40GB file (zeroes) on both: 1.45 to 1.68A, CPU temp max: 45C, Disk a: 30C and 180MB/sec, Disk B: 30C and 171MB/sec
- Same plus stressing CPU (sqrt) on 4 cores: 1.57 to 1.80, CPU temp max: 51C
- Same plus two additional SSD attached via unpowered USB 3 (SSD not connected to SATA): 1.90A to 2.12A, CPU temp max: 55C (I believe the 55C was reached because I did not wait too much after the previous test).
Note: the test below is now with the NAS case closed. CPU Fan control still set at 127. Case Fan 80mm set at 2/3 speed. Room temperature 24C.
- Idle CPU at 34C
- Idle disks at 29C
(6) Writing 40GB file (zeroes) on both disks.
- 1.64A to 1.89A, CPU temp max: 45C, both disks at 30C. Note: the slightly extra load in amps is from the case FAN and the mini-card controller I added.
CONCLUSION: so far, so very good, extra room in power with the 12v 5A PSU.
Other remarks:
- The U.FL MHF4 plugs are a hassle, once you start to put all the pieces into places they have the tendency to disconnect. You basically have to connect them last which a big pain in the neck when you have big fingers.
- I'll test again the temps with the case fan at half and 1/3 the power.
- I'll receive the Marvell 88SE9230 4-port card from Aliexpress in about a month (just to play with 2 HD + 2 SSD). For HyperDuo it will be a challenge because I did not find a software to configure it on Linux yet (but there is a driver) and there is no BIOS so no config via the BIOS either. Still Googling. Anyway, I think this card will end up in a PC.
NAS case testing with Armbian_5.88_Rockpro64_Ubuntu_bionic_default_4.4.180_desktop - by domih - 06-17-2019, 03:45 AM
  NAS case HDD power cable failure (buck failure) ashleymills 1 1,911 04-01-2022, 11:25 AM
Last Post: ashleymills
  Plugging In Case Fan and CPU Fan publiclewdness 0 1,428 01-04-2022, 09:58 AM
Last Post: publiclewdness
  Nas Case out of stock Goffi 2 2,270 12-04-2021, 05:14 AM
Last Post: Goffi
  RP64 TV box case with wifi Wizzard 2 3,294 03-10-2021, 12:23 AM
Last Post: Wizzard
Question 1U Rackmount Case for ROCKPro64 tuaris 3 5,013 02-18-2021, 08:09 PM
Last Post: TRS-80
  NAS Case: Issues with hardware installation, esp. screws kuleszdl 0 1,728 01-09-2021, 05:24 PM
Last Post: kuleszdl
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 12,712 01-05-2021, 05:05 PM
Last Post: kuleszdl
  Release CAD files for NAS case or parts of it? diizzy 5 5,508 08-13-2020, 04:50 AM
Last Post: diizzy
  Best location for adhesive wifi antennas with NAS case callegar 1 3,062 02-17-2020, 12:40 PM
  RP64 NAS Case, 1 month in Tim Jones 1 2,912 07-29-2019, 04:16 PM
Last Post: Luke
