Install OS on RAID1 thanks to dual SATA board?
I figured it out! I updated the list of steps above with the fix.
The gist of it is that "btrfs device scan" must be run before a multi-device btrfs filesystem can be mounted. I don't know why this is the case, but it is. See: https://btrfs.wiki.kernel.org/index.php/...e_scanning
From there, it was just a matter of figuring out how to get this command to be run before the root filesystem is mounted. I used initramfs-tools to cause a simple script to be run on bootup to do this. For that to take effect, the initramfs image has to be updated. See the updated steps in my earlier post for exactly how to do it.
If you follow my steps, please let me know how it turns out!
RE: Install OS on RAID1 thanks to dual SATA board? - by markb1 - 05-15-2019, 02:20 PM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 679 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Star64: SATA Der Geist der Maschine 1 1,022 07-26-2023, 12:35 PM
Last Post: Gladox114
  PBP Debian 11 GRUB install error zlth 2 1,951 11-18-2022, 07:42 AM
Last Post: zlth
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,579 10-06-2022, 08:46 PM
Last Post: ihab
  wrong launguage install chadace 1 4,050 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 6,471 03-18-2020, 09:42 AM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,474 06-26-2018, 11:37 AM
Last Post: Luke
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,199 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  My first Single Board! jjh221 4 6,788 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,409 03-31-2018, 04:09 AM
Last Post: pfeerick
