RPi.GPIO python module for Pine A64/A64+
#91
(04-10-2018, 03:17 AM)xalius Wrote: Are you using spidev?
I'm not sure, but I don't think so. I put my code on github here so you can see what I'm doing.
I initially took the code from Adafruit, but since this library uses a different implementation for SPI (and I2C) I modified it to work on the pine64.
Nokia5110.py is my modified library.
nokia_test2.py draws some shapes and text on the display.
nokia_clock2.py draws a very simple analog clock.
RE: RPi.GPIO python module for Pine A64/A64+ - by psychedup - 04-10-2018, 08:31 AM
  fm transmitter with gpio weasel18 2 4,827 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,594 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,116 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,195 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,845 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,577 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,757 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,157 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 15,982 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,089 11-10-2016, 06:07 PM
Last Post: joseph
