RPi.GPIO python module for Pine A64/A64+
#31
(06-19-2016, 07:56 AM)martinayotte Wrote: In my case, RPi.GPIO-PineA64 worked out of the box using "python setup.py install", nothing else to do.
Beware that pyA20 doesn't use the same pins for A64, so some GPIOs are working but some other won't or simply not defined.
Hmm okay. Maybe it's time to try a fresh OS. What kernel version are you running on the OS that RPi.GPIO for Pine is working on?
RE: RPi.GPIO python module for Pine A64/A64+ - by jacobscarter - 06-19-2016, 10:48 AM
  fm transmitter with gpio weasel18 2 4,845 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 3,611 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 11,172 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 11,242 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 11,897 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 31,713 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 14,813 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 21,235 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 16,056 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 6,118 11-10-2016, 06:07 PM
Last Post: joseph
