Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment
(06-18-2019, 08:06 AM)tuxd3v Wrote: I use a Fan to vent the disks, and I have configured the disks for power saving
Do you also use the ROCKPro64 Metal Desktop / NAS Casing or something else?
(06-18-2019, 08:06 AM)tuxd3v Wrote: ( They are majority of time in APM mode 1, Because when you configure them in APM 127, after some time without activity they enter in APM mode 1, also known as StandBy..only the Controller board is in part activated,..this saves energy, the disks, and lower the temps.. ) ..
OK. I understood that.
Please tell me the right command to configure on for example 128 or 192. Is that correct? --> ./openSeaChest_PowerControl --device /dev/sda --setAPMLevel 128
And the right command to configure spindown time. I want to set 30 to 60 minutes. Is that possible?
(06-18-2019, 08:06 AM)tuxd3v Wrote: Load/Unload,
You posted the 'Power Cycles' of your disks..
And that is  a preoccupation, because you have ~3000-5000 'Power Cycles'( SMART attribute 12, the Load/Unload is SMART attribute 193 ).
That tells me that, your disks fail to start a lot of times due to not sufficient power budget..
Probably because they are in 'Performance' Mode..
I'll test that with for blockid in {a..d};do smartctl --attributes /dev/sd${blockid}|grep -E "^ 12|^193"; done for a week.
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 9,416 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,330 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 52,194 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,140 10-23-2020, 11:56 AM
Last Post: hmuller
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 74,312 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,678 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,919 11-06-2018, 01:03 PM
Last Post: tuxd3v
