Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment
(06-14-2019, 05:08 AM)Neo2018 Wrote: my hard drive ----> is sda1 (new one: Seagate IronWolf 8TB)
p@p-ubuntu:~$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
loop0    7:0    0  34,6M  1 loop /snap/gtk-common-themes/818
loop1    7:1    0   2,3M  1 loop /snap/gnome-calculator/260
loop2    7:2    0    13M  1 loop /snap/gnome-characters/139
loop3    7:3    0 140,7M  1 loop /snap/gnome-3-26-1604/74
loop4    7:4    0  14,5M  1 loop /snap/gnome-logs/45
loop5    7:5    0   3,7M  1 loop /snap/gnome-system-monitor/57
loop6    7:6    0    91M  1 loop /snap/core/6350
sda      8:0    0   7,3T  0 disk
└─sda1   8:1    0   7,3T  0 part /media/p/Daten3
sdb      8:16   0 489,1G  0 disk
└─sdb1   8:17   0   489G  0 part
sdc      8:32   0 465,8G  0 disk
├─sdc1   8:33   0   499M  0 part
├─sdc2   8:34   0   100M  0 part /boot/efi
├─sdc3   8:35   0    16M  0 part
├─sdc4   8:36   0 254,2G  0 part
├─sdc5   8:37   0 173,6G  0 part
└─sdc6   8:38   0  37,3G  0 part /
sr0     11:0    1  1024M  0 rom
next step i want ---> 2). Set Low Current SpinUP
root@p-ubuntu:~/openSeaChest/Make/gcc/openseachest_exes# ./openSeaChest_Basics --deviceInfo --device /dev/sda1
openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled
Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved
openSeaChest_Basics Version: 2.8.0-1_19_0 X86_64
Build Date: Jun 13 2019
Today: Fri Jun 14 12:19:45 2019
/dev/sg0 - 3.0 -            XYZW - ATA
Vendor ID: USB
Model Number: 3.0
Serial Number:
Firmware Revision: 0508
Temperature Data:
Current Temperature (C): 45
Highest Temperature (C): 50
Lowest Temperature (C): 23
Low Current Spinup: Disabled
SMART Status: Unknown or Not Supported
SATA Software Settings Preservation [Enabled]
SMART [Enabled]
PUIS [Enabled]
How do I set the settings to 127 with 1 hour spitdown?
root@p-ubuntu:~/openSeaChest/Make/gcc/openseachest_exes# for blockid in {a..d};do smartctl --attributes /dev/sd${blockid}|grep -E "^ 12|^193"; done
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       3110
12 Power_Cycle_Count       0x0032   094   094   000    Old_age   Always       -       5471
root@p-ubuntu:~/openSeaChest/Make/gcc/openseachest_exes# ./openSeaChest_PowerControl --device /dev/sda1 --setAPMLevel 127
openSeaChest_PowerControl - openSeaChest drive utilities - NVMe Enabled
openSeaChest_PowerControl Version: 1.10.0-1_19_0 X86_64
Today: Fri Jun 14 12:49:32 2019
/dev/sg0 - 3.0 -            BCDEF - ATA
Setting APM Level is not supported on this device.
why, where is the mistake?
root@p-ubuntu:~/openSeaChest/Make/gcc/openseachest_exes# ./openSeaChest_PowerControl --showAPMLevel --device /dev/sda1
Today: Fri Jun 14 12:58:28 2019
Showing APM Level is not supported on this device.
I'm desperate again
Please explain this to me please (for dumheads like me)
Hello Neo2018,
You need to breath , no need to be with all that pressure..  Shy
For What I see from your post..
You have 2 disks there( but your Seagate is sda )!
sda1, sdb1,2,3 ... Are Partitions, **NOT disks**
You should configure **disks**, not partitions.. use '/dev/sda' to configure steps..
Apart from that, the Only explanation I could find is related with your USB->Sata Adapter.. some commands are accepted some don't..  Sad
Try installing, in the machine you setup Ubuntu:
apt-get install -y sg3-utils
reboot
The step 3), I think you can set it up with 'smartmontools'( in rockpro64.. ), so forget it for now..
Repeat steps 1),2),4),5) in the Ubuntu machine you setup, after installing 'sg3-utils', using '/dev/sda' has disk.
If that Doesn't work:
There have been some development in OpenSeachest to try to add more support for kernels without some functionalities( its in the 'master' branch now.. )
Has a last resource you could build OpenSeachest 'master' branch, and retest, but for now, forget this option..
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 9,788 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,384 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 53,084 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,221 10-23-2020, 11:56 AM
Last Post: hmuller
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 75,760 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,725 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,971 11-06-2018, 01:03 PM
Last Post: tuxd3v
