Utility to make Android SDCard image
First you need to download the correct file, some are for eMMc boot and some are for the SD card.
Once you do that, i had the best luck with a tool called "balenaetcher" it will uncompress the file then flash it to the card.
The other programs i tried you need a zip program to first unzip the file before you flash it, i found this one to be the most simple and easiest but its just my opinion.
Ive had my board for about a week now and ive been trying about every version of Android so far i like the "Android TV 7.1 Community Build Image [microSD Boot] by ayufan" its way down at the bottom on the wiki.pine64.org download section.
Even though im not a fan of the leanback launcher style it runs the best on and SD card ive found
RE: Utility to make Android SDCard image - by BowerR64 - 09-09-2020, 06:59 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,220 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,010 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,534 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,180 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,002 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,479 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,983 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,567 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,702 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,760 09-09-2020, 08:44 AM
Last Post: BowerR64
