problems getting android on rock64
(02-18-2019, 04:03 PM)IbrokeTTL Wrote:
(01-15-2019, 03:03 AM)mranderson Wrote: I've been trying to use an eMMC adapter and tried burning the images "7.1.2. rooted emmc" and "8.1 emmcboot" to the emmc but when I place it in the rock64, it will not boot or even show an image over hdmi. What am I doing wrong here?
I get the same - Are you able to get the SD versions working? Also are you getting any output on the USB to TTL connection? From what i understand the boot process can take 10+ minutes for the first time.
One other thing to note - the default resolution is @ 1080. My monitor can't do that (it's an old lab monitor) and i thought it was a boot issue for a while.
RE: problems getting android on rock64 - by IbrokeTTL - 02-22-2019, 04:43 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,111 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,909 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,478 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 166,852 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,952 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,432 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,890 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,531 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,643 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,640 09-09-2020, 08:44 AM
Last Post: BowerR64
