OS for 512mb?
(06-16-2016, 11:15 AM)ottu Wrote:
(06-16-2016, 09:04 AM)Luke Wrote:
(06-16-2016, 08:57 AM)ottu Wrote:
(04-21-2016, 03:32 PM)tllim Wrote:
(04-20-2016, 06:39 PM)joshdude58 Wrote: Hello, I recently received my Pine 64 512mb model and have yet to successfully get it booted. I have tried installing android 5.1.1, remix os, and arch linux (all listed on the wiki page), but had no luck. I understand that these state they are tried/require the 1gb model, but I am very eager to get started with my pine. Are there any operating systems the pine 64 512mb model can run? Thanks!
As mentioned on KS page and also FAQ, Android, including Remix, not suitable for Pine A64 512MB board. The best OS for Pine A64 board is ArchLinux.
Looks like Arch Linux for Pine has been discontinued. I downloded a xubuntu minimal version from the same developer and it doesn't boot, installed Debian and it's so slow that I am considering whether my Commodore 64 is a better option. All the other OSes are for 1GB according with the Pine official page. I tested a few of them and in fact they don't seem to work. Any suggestion? Should I use my long waited Pine A64 board to play frisbee?
Debian runs really nicely on the 512mb board. I dont know about using a de (I would presume it will be sluggish) but for headless applications its great. I have just gotten my 512 board and moved my webserver to it. Works great. Why would you get a 512 board if you want a de ?
Hi Luke, thanks for your reply. Good to hear that for headless applications works well. I was trying to use the built in web browser and gave up because it was too slow, then installed konqueror and it was even worst. I have an old netbook running Linux Mint and it works fine. I was hoping to find a similar distribution for the Pine A64. No frills, just web browsing, open office and nothing more. Should I assume that it's impossible to achieve with the pine A64?
Was too slow ? no way. I will PM you the site I'm hosting so you can try it out. Nothing spectacular, but you can hardly call it slow ... How did you set it up ?
Think that comparing an old netbook to the pine isnt really fair - CPU architecture, RAM type/size, type of storage, etc. But that is besides the point - the 512mb board will be very limiting for desktop applications ...
OS for 512mb? - by joshdude58 - 04-20-2016, 06:39 PM
RE: OS for 512mb? - by frewind - 04-20-2016, 11:06 PM
RE: OS for 512mb? - by tllim - 04-21-2016, 03:32 PM
RE: OS for 512mb? - by ottu - 06-16-2016, 08:57 AM
RE: OS for 512mb? - by Luke - 06-16-2016, 09:04 AM
RE: OS for 512mb? - by ottu - 06-16-2016, 11:15 AM
RE: OS for 512mb? - by Luke - 06-17-2016, 03:07 AM
RE: OS for 512mb? - by xalius - 06-16-2016, 11:21 AM
RE: OS for 512mb? - by ottu - 06-16-2016, 12:11 PM
RE: OS for 512mb? - by xalius - 06-16-2016, 12:16 PM
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,542 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
