Assembling the premium aluminum case
(07-02-2021, 05:24 PM)tllim Wrote:
(05-26-2021, 11:23 AM)CounterPillow Wrote: The board not being mounted in the centre is completely fine, it does not interfere with the case closing. Make sure you put the lid the right way around
[Image: thisisfine.jpeg]
Some more things to note:
1. pull out the plastic light guide before trying to insert the rock64
2. pull out the rubber plug before trying to insert the rock64
3. when closing, try not pushing the top straight down, but coming in from the side with the ports and levering it in.
Here's some more pictures. On this, note how the mounting posts are spaced exactly like yours. This isn't the issue.
[Image: IMG_20210526_193219.jpg]
on this one, note how the HDMI and 3.5mm socket are poking through the case. This is still what I suspect your issue is; it'll seem like the board is mounted too far off to one side, but actually, it's that it's not clearing the holes.
[Image: IMG_20210526_193559.jpg]
@CounterPillow, appreciated and thanks on your installation description. Thumbs Up.
Nice to see users sharing their experiences here and documenting them too. So important for others coming behind. Well done.
RE: Assembling the premium aluminum case - by Rocklobster - 07-07-2021, 05:50 AM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 611 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 3,472 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 16,425 03-04-2022, 06:56 AM
Last Post: killor
Heart Best quick/easy way to control case fan speed? idillicah 4 5,953 06-24-2021, 09:14 AM
Last Post: CounterPillow
  What thermal compound will fit better to the aluminum case? m.bakhterev 1 2,946 01-26-2020, 12:56 PM
Last Post: clach04
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 16,005 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 5,863 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 3,727 02-20-2019, 01:27 AM
Last Post: made2hack
  Raspberry Pi OneNineDesign Case "Mod" MichaelRock 2 3,805 06-20-2018, 04:23 PM
  Is recommended to buy the case? enreador 1 2,851 05-03-2018, 03:55 PM
Last Post: evilbunny
