Can't connect to wifi on a Rock64
I'm trying to set up a Rock64 to connect to wifi using a Panda PAU09 USB wifi adapter.  The adapter is mounted in a fixed location, and when connected to my laptop running Ubuntu Bionic, I am able to easily connect to my own wifi network, as well as my school's secure network and their guest network using NetworkManager.  However, when I connect the adapter to the Rock64, I am unable to connect to any wifi networks, in spite of seeing them listed when I do a network scan.  I have tried this using Armbian Stretch and Bionic images, and also using ayufan's Bionic image.  When using nmcli to bring up the connection, I usually receive the error message "The Wi-Fi network could not be found".  However, scanning for networks usually shows the network I am attempting to connect to with good signal strength.  Other times, the connection will actually "succeed" but I won't be able to communicate over it and then the connection just goes down within seconds.
Any ideas on how I could make this work?
Can't connect to wifi on a Rock64 - by SuperSaiyanCaleb - 12-18-2018, 07:14 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,362 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 335 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,389 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,563 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,414 12-07-2022, 08:22 PM
Last Post: luminosity7
