Wifi problem
(11-27-2018, 08:36 AM)Nether494 Wrote: My wifi dongle -> https://www.aliexpress.com/item/Rocketek...15976.html
This is a RTL8811AU
Bus 002 Device 002: ID 0bda:a811 Realtek Semiconductor Corp.
Ok. Let's try again.
  • Realtek drivers are chaotic. Only few people has time to make it working.
  • Do not use https://github.com/sloretz/rtl8811au -> not for 4.x kernel (for example STATION_INFO_SIGNAL is missing in kernel sources...)
  • Let's try with https://github.com/zebulon2/rtl8812au/tree/v5.1.5
    $ sudo bash
    # git clone --depth 1 https://github.com/zebulon2/rtl8812au.git
    # cd rtl8812au
    # ### pre-check (0bda:a811)
    # grep A811 ./os_dep/linux/usb_intf.c
        {USB_DEVICE(USB_VENDER_ID_REALTEK, 0xA811) , .driver_info = RTL8821},/* Default ID */
        {USB_DEVICE(0x7392, 0xA811), .driver_info = RTL8821}, /* Edimax - Edimax */
        {USB_DEVICE(0x0BDA, 0xA811),.driver_info = RTL8821}, /* Comfast - CF-915AC */
    # ### section "#ifdef CONFIG_RTL8821A" so check enabled RTL8821A
    # grep "CONFIG_RTL8821A = y" Makefile
    CONFIG_RTL8821A = y
    # ### Makefile is set for "CONFIG_PLATFORM_I386_PC = y", it is probably ok for generic linux
    # ### compile for Rock64, last stable 64bit ayufan image
    # uname -a
    Linux rock64 4.4.132-1075-rockchip-ayufan-ga83beded8524 #1 SMP Thu Jul 26 08:22:22 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
    # make -j4 ARCH=arm64 USER_EXTRA_CFLAGS="-Wno-switch-unreachable"
    # make install
    # ### check module load (I do not have your HW)
    # modprobe 8812au
    # modinfo 8812au
    filename:       /lib/modules/4.4.132-1075-rockchip-ayufan-ga83beded8524/kernel/drivers/net/wireless/8812au.ko
    version:        v5.1.5_19247.20160830
    author:         Realtek Semiconductor Corp.
    description:    Realtek Wireless Lan Driver
    license:        GPL
    srcversion:     E7ABE344F6E3D275044CA78
    alias:          usb:v0BDApA811d*dc*dsc*dp*ic*isc*ip*in*
    depends:
    vermagic:       4.4.132-1075-rockchip-ayufan-ga83beded8524 SMP mod_unload aarch64
    parm:           rtw_ips_mode:The default IPS mode (int)
    # modinfo 8812au | grep v0BDApA811
    # ### so, supported by kernel module
Buy me a Beer.
I left this community in Aug 2019 due to PINE64 refusal to produce/deliver ROCK64-1G version 3 after more than one year of changing statuses to "planning", "evaluating", "releasing", "availability", "estimated availability" and finally "no schedule" Angry. ROCK64 is dead platform without any advantage. Buy Raspberry PI 4 !
Away
Wifi problem - by Nether494 - 11-27-2018, 08:36 AM
RE: Wifi problem - by Nether494 - 11-27-2018, 11:59 AM
RE: Wifi problem - by evilbunny - 11-27-2018, 03:42 PM
RE: Wifi problem - by Nether494 - 11-27-2018, 06:21 PM
RE: Wifi problem - by evilbunny - 11-27-2018, 07:33 PM
RE: Wifi problem - by Nether494 - 11-28-2018, 04:28 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 04:43 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 05:07 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 05:37 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 05:51 AM
RE: Wifi problem - by evilbunny - 11-28-2018, 06:26 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 06:32 AM
RE: Wifi problem - by mcerveny - 11-28-2018, 09:48 AM
RE: Wifi problem - by Nether494 - 11-28-2018, 01:48 PM
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,266 10-12-2023, 05:14 PM
Last Post: tpaul
  External hard drive problem k8Va 17 22,406 03-09-2021, 02:31 PM
Last Post: calinb
  Arch Linux Arm - external RTC problem max 1 2,961 08-17-2020, 10:35 AM
Last Post: max
  Read-only problem mikedhoore 5 6,849 07-14-2020, 11:41 AM
Last Post: zein
Question bluetooth rock64 problem deta 3 5,041 05-06-2020, 11:29 PM
Last Post: deta
  Fedora 31 crosscompilation fdt problem mimics debian 888789 kf5zmi 2 4,142 01-20-2020, 12:25 PM
Last Post: kf5zmi
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,262 03-26-2019, 07:28 PM
Last Post: Poincare
  ROCK64 Kernel compilation problem cao 0 2,462 01-21-2019, 01:21 AM
Last Post: cao
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 4,163 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
  8812au wifi driver OS pane 9 10,960 11-19-2018, 02:46 AM
Last Post: pane
