how to build Stock Android Oreo 8.1 from source code for rock64?
(03-13-2019, 02:52 PM)jonsmirl Wrote: The Android source is set up to use the flash. You are booting from SD card and don't have a flash module. I tried screwing around with the source to adjust it to work from only SD card. I gave up after a while and bought a flash module.
It is unable to mount things because it is trying to mount them from the flash device.
I don't have an EMMC Module and don't wish to buy one as I am using Rock64 in one of my products and EMMC Module is costlier as compared to SD Cards.
It would be better if Pine64 provides a patch file to fix things. They have released Android Oreo 8.1.0 Image for SD Boot so they should have the working source code with them.
(03-16-2019, 06:16 AM)aurel Wrote: Hi,
What is the way to compile ? I tried 'source build.sh' but Build uboot failed ? Am I missing some tools ?
Probably. Posting the error logs on del.dog and sending the link here would allow me to help you
RE: how to build Stock Android Oreo 8.1 from source code for rock64? - by shripal17 - 03-17-2019, 08:06 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,246 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,016 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,541 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,292 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,012 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,496 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,999 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,719 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,767 09-09-2020, 08:44 AM
Last Post: BowerR64
