Chromium?
(07-07-2016, 02:35 PM)janeku Wrote: It says dependency is not satsifiable : libdbus-1-3 (>=1.9.14)
This is output error when trying to install suggested deb file
Edit: Installed chromium_51.0.2704.63-2.2linarojessie1_arm64.deb , and ran with suggested credentials. Work good. Youtube works perfect. If I try to run as it is installed it says no connection. Anyway it will do the job till next fixture.
Regards,
Where can I get that chromium_51.0.2704.63-2.2linarojessie1_arm64.deb package? I'm getting the same error on my 2gb pine64 running the newest headless Debian image.
Edit: Nevermind, found the link to Chromium packages in an earlier post in this thread. ( http://repo.linaro.org/ubuntu/linaro-ove...m-browser/ )
Edit #2:
Successfully installed! Here are the steps:
1. Download chromium_51.0.2704.63-2.2linarojessie1_arm64.deb from this page. (It's near the bottom of the list)
2. Open your terminal and cd into wherever it downloaded ( most likely `cd ~/Downloads` )
3. Run `sudo gdebi chro*` to install chromium along with its dependencies
4. Now you can run it whenever with `chromium --disable-seccomp-filter-sandbox --disk-cache-size=200`
Optional: Make a shortcut alias command for `chromium --disable-seccomp-filter-sandbox --disk-cache-size=200`
1. Run `alias chrome='chromium --disable-seccomp-filter-sandbox --disk-cache-size=200'`
2. Now you can just run `chrome &` to boot up chrome in a background process with the required flag
Some with certainty insist no certainty exists.
Chromium? - by Sailing_Nut - 04-18-2016, 02:52 PM
RE: Chromium? - by lenny.raposo-pine64.pro - 04-18-2016, 05:38 PM
RE: Chromium? - by Sailing_Nut - 04-18-2016, 06:53 PM
RE: Chromium? - by androsch - 04-19-2016, 12:52 AM
RE: Chromium? - by Sailing_Nut - 04-19-2016, 06:11 AM
RE: Chromium? - by baryluk - 04-23-2016, 02:32 PM
RE: Chromium? - by geffas - 04-24-2016, 04:26 AM
RE: Chromium? - by Mr.Thinker - 10-09-2016, 01:51 PM
RE: Chromium? - by baryluk - 01-02-2017, 12:25 PM
RE: Chromium? - by victagayun - 02-07-2017, 08:06 AM
RE: Chromium? - by victagayun - 02-07-2017, 05:30 PM
RE: Chromium? - by victagayun - 02-08-2017, 07:04 AM
RE: Chromium? - by baryluk - 04-25-2016, 07:29 PM
RE: Chromium? - by victagayun - 10-09-2016, 07:31 AM
RE: Chromium? - by neeeds - 05-21-2016, 12:24 PM
RE: Chromium? - by janeku - 07-06-2016, 11:21 PM
RE: Chromium? - by dkryder - 07-07-2016, 02:29 AM
RE: Chromium? - by barawn - 07-08-2016, 06:36 AM
RE: Chromium? - by janeku - 07-08-2016, 02:18 PM
RE: Chromium? - by dkryder - 07-08-2016, 02:36 PM
RE: Chromium? - by janeku - 07-08-2016, 02:41 PM
RE: Chromium? - by dkryder - 07-08-2016, 04:55 PM
RE: Chromium? - by janeku - 07-07-2016, 02:35 PM
RE: Chromium? - by dkryder - 07-07-2016, 11:44 PM
RE: Chromium? - by Prophesi - 07-08-2016, 07:56 AM
RE: Chromium? - by cantcode - 07-15-2016, 12:10 PM
RE: Chromium? - by Monochrome - 07-15-2016, 12:13 PM
RE: Chromium? - by cantcode - 07-15-2016, 01:08 PM
RE: Chromium? - by Monochrome - 07-15-2016, 03:21 PM
RE: Chromium? - by jrullan - 07-08-2016, 06:58 PM
RE: Chromium? - by xalius - 07-09-2016, 06:46 AM
RE: Chromium? - by psychedup - 07-09-2016, 03:31 PM
RE: Chromium? - by Luke - 07-09-2016, 05:41 PM
RE: Chromium? - by psychedup - 07-10-2016, 11:07 AM
RE: Chromium? - by xalius - 07-10-2016, 12:18 PM
RE: Chromium? - by Monochrome - 07-13-2016, 08:59 AM
RE: Chromium? - by cantcode - 07-18-2016, 08:52 AM
RE: Chromium? - by jkmooney - 07-18-2016, 01:36 PM
RE: Chromium? - by cantcode - 07-22-2016, 07:08 AM
RE: Chromium? - by jrullan - 07-22-2016, 08:21 PM
RE: Chromium? - by cantcode - 07-26-2016, 11:11 AM
RE: Chromium? - by jrullan - 07-27-2016, 08:31 PM
RE: Chromium? - by Prophesi - 07-28-2016, 09:17 AM
RE: Chromium? - by dkryder - 07-30-2016, 01:53 AM
RE: Chromium? - by rallar8 - 08-30-2016, 05:06 PM
RE: Chromium? - by criageek - 09-08-2016, 09:09 AM
RE: Chromium? - by UnixOutlaw - 09-22-2016, 11:07 PM
RE: Chromium? - by MarkHaysHarris777 - 09-23-2016, 10:19 PM
RE: Chromium? - by S265 - 09-25-2016, 05:28 PM
RE: Chromium? - by Gnx - 05-26-2017, 11:24 AM
RE: Chromium? - by dkryder - 05-26-2017, 01:23 PM
RE: Chromium? - by pfeerick - 05-26-2017, 06:07 PM
RE: Chromium? - by Luke - 05-26-2017, 05:01 PM
RE: Chromium? - by dkryder - 05-26-2017, 09:17 PM
RE: Chromium? - by Luke - 05-27-2017, 06:33 AM
RE: Chromium? - by Gnx - 05-27-2017, 12:06 PM
RE: Chromium? - by dkryder - 05-27-2017, 05:22 PM
RE: Chromium? - by Luke - 05-28-2017, 01:56 PM
RE: Chromium? - by Gnx - 05-28-2017, 04:39 PM
RE: Chromium? - by Luke - 05-28-2017, 04:49 PM
RE: Chromium? - by dkryder - 05-28-2017, 06:28 PM
RE: Chromium? - by Gnx - 05-30-2017, 03:18 AM
RE: Chromium? - by Luke - 05-30-2017, 04:04 AM
RE: Chromium? - by Gnx - 05-30-2017, 06:33 AM
  Midori and Chromium (52) Cannot open display DuMees 3 5,865 01-12-2017, 02:36 AM
Last Post: DuMees
