8812au wifi driver OS
(11-19-2018, 12:35 AM)evilbunny Wrote:
(11-18-2018, 10:06 PM)pane Wrote: The system image I am trying to install into is stretch-minimal-rock64-0.7.9-1067-arm64.img.xz from ayufan's repo. I have tried on others too. I do not need to use any OS in particular, I just need an image that works with this wifi driver. It can be desktop or headless, I don't mind as long as the 8812au driver works
I mostly use deb minimal, and that deb package should work fine. The only thing I can think of is I use dpkg -i <package>.deb rather than apt. I also have dkms and build-essential packages installed.
Alright, thanks. I did update but did not build essentials and manually installed python instead. I will try using your method now, and report back with how I go
8812au wifi driver OS - by pane - 11-18-2018, 09:16 PM
RE: 8812au wifi driver OS - by evilbunny - 11-18-2018, 09:31 PM
RE: 8812au wifi driver OS - by pane - 11-18-2018, 10:06 PM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 12:35 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 01:16 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 01:41 AM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 01:52 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 02:32 AM
RE: 8812au wifi driver OS - by evilbunny - 11-19-2018, 02:39 AM
RE: 8812au wifi driver OS - by pane - 11-19-2018, 02:46 AM
  on-board ethernet driver michaelanburaj 0 1,827 03-26-2020, 12:01 PM
Last Post: michaelanburaj
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,230 03-26-2019, 07:28 PM
Last Post: Poincare
  Can't connect to wifi on a Rock64 SuperSaiyanCaleb 2 4,090 12-18-2018, 11:51 PM
Last Post: SuperSaiyanCaleb
Lightbulb Wifi problem Nether494 13 17,148 11-28-2018, 01:48 PM
Last Post: Nether494
  WiFi on Armbian problem scalextrix 14 17,479 09-08-2018, 01:13 AM
Last Post: scalextrix
  OMV wifi setup (driver issue) six9 0 2,297 07-25-2018, 03:34 PM
Last Post: six9
  wifi dongle pas059 3 3,815 05-30-2018, 12:25 PM
Last Post: pas059
  rtl8812au driver install.. 11b2p508 11 16,058 05-20-2018, 01:36 AM
Last Post: brajul
  How can I get a driver to support my USB wifi dongle Rocklobster 4 5,863 04-19-2018, 12:55 PM
Last Post: Rocklobster
  alpha wifi rt3572 cinaed 0 1,530 02-15-2018, 03:04 PM
Last Post: cinaed
