Rock64 With Android TV 7.1 Won't boot using 3.5mm power barrel
I can only get the Rock64 to boot with a USB A-2-A cable. If I plug in a cable to the barrel it won't boot.
I am using this for power: https://www.tronsmart.com/products/w2ptu...ll-charger
With a cable like this: https://www.amazon.ca/Duttek-3-5x1-35-Ch...ower&psc=1
[url=https://www.amazon.ca/Duttek-3-5x1-35-Charging-Electronics-Converter/dp/B07DL1DV7T/ref=sr_1_1_sspa?ie=UTF8&qid=1542236800&sr=8-1-spons&keywords=usb-a+3.5mm+power&psc=1][/url]
Would the only reason be that the USB-A port on this charger is not providing 5V-3A? If I use this adapter should I get a USB-C to USB-A cable to make this adapter work?
Rock64 With Android TV 7.1 Won't boot using 3.5mm power barrel - by Eric82 - 11-14-2018, 05:09 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,203 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 5,981 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,525 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,015 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,986 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,467 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,949 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,555 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,691 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,726 09-09-2020, 08:44 AM
Last Post: BowerR64
