OTG on Android
Thanks for your reply. I want to connect a DJI controller, but you probably don't have one at your disposal. I guess performing a data transfer would prove that the ROCK64 is working in slave mode. So it would be great if you could test this for me! Be aware that you will have to connect the top USB 2.0 port of the ROCK64 to your computer, as this is the USB OTG port. And while you're at it, maybe you can try to connect it to a different port is well (for instance the bottom USB 2.0 port) and see if you're still able to make the data transfer. If you are able to make the transfer in the first test but not the second, I'm confident that all drivers are there and everything is alright.
Your help is much appreciated,
Onderbetaald
OTG on Android - by onderbetaald - 11-12-2018, 09:52 AM
RE: OTG on Android - by geno - 11-13-2018, 04:13 AM
RE: OTG on Android - by onderbetaald - 11-13-2018, 05:33 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,254 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,020 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,547 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,418 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,016 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,498 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,005 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,574 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,722 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,774 09-09-2020, 08:44 AM
Last Post: BowerR64
