Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working
Hello all,
Rockpro64 has MidGard Mali-T860, Graphics Card,
It has support at least for OpenCl 1.2 FULL_PROFILE( I don't know about OpenCL2.0?! )
For those wanting to try it, in Lua,
There are a project mooncl( which are the Lua Bindings for the Official Khronos OpenCL™ API , by stetre )
It supports Lua >= 5.3 and OpenCL >= 1.2, ... so Rockpro64 is there too!! Cool
You will need:
  1. The last stable release of  ARM OpenCLComputeLibrary
    as root(Compile it for example during the night...it will take hours..)
  2. After compile it,
    Check if ARM opencl icd is ok:
    cat /etc/OpenCL/vendors/mali.icd
    libMaliOpenCL.so
  3. Run a test, on ARM OpenCLCompute Library:
    cd /opt/ComputeLibrary && LD_LIBRARY_PATH=build/ ./build/examples/cl_convolution
    Test passed
  4. The mooncl Bindings for the Official Khronos OpenCL™ API
    as normal user ( ie: rock64 )
    cd /home/rock64/Desktop && git clone https://github.com/stetre/mooncl.git && cd mooncl
    make
    sudo make install
    It installed the shared library and headers in /usr/local( has expected )
  5. 1st test :
    lua examples/platforminfo.lua
       Found 1 platform.
       platform no. 1:
       - name: ARM Platform
       - vendor: ARM
       - version: OpenCL 1.2 v1.r14p0-01rel0-git(966ed26).f44c85cb3d2ceb87e8be88e7592755c3
       - profile: FULL_PROFILE
       - extensions:
          cl_khr_global_int32_base_atomics
          cl_khr_global_int32_extended_atomics
          cl_khr_local_int32_base_atomics
          cl_khr_local_int32_extended_atomics
          cl_khr_byte_addressable_store
          cl_khr_3d_image_writes
          cl_khr_fp64
          cl_khr_int64_base_atomics
          cl_khr_int64_extended_atomics
          cl_khr_fp16
          cl_khr_gl_sharing
          cl_khr_icd
          cl_khr_egl_event
          cl_khr_egl_image
          cl_khr_image2d_from_buffer
          cl_arm_core_id
          cl_arm_printf
          cl_arm_thread_limit_hint
          cl_arm_non_uniform_work_group_size
          cl_arm_import_memory
       - devices:
          1: Mali-T860 (OpenCL 1.2 v1.r14p0-01rel0-git(966ed26).f44c85cb3d2ceb87e8be88e7592755c3 - FULL_PROFILE)
    Mali-T860 is detected and in OpenCL 1.2 FULL_PROFILE!!!  Cool
  6. 2nd test( sum 20 + 30 in OpenCl):
    lua examples/hello.lua
    20 + 30 = 50
    Nice!!
Now the Sky is the Limit for you!!!!
Kudos for stetre for providing the Lua Bindings..
Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working - by tuxd3v - 11-06-2018, 01:03 PM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 9,688 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,365 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 52,849 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,199 10-23-2020, 11:56 AM
Last Post: hmuller
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 23,921 06-19-2019, 04:40 AM
Last Post: Neo2018
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 75,492 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,717 02-26-2019, 07:21 PM
Last Post: tuxd3v
