Docker Swarm Cluster with pine64-lts and armbian build
(10-31-2018, 03:35 AM)tmorin Wrote: Hi,
For those interested you will find below details to setup a Docker Swarm cluster of pine64-lts boards.
All nodes are running with Armbian and the mainline kernel (currently 4.14). In order to boot pine64-lts boards using the Armbian build for pine64so, some additional fixes have to be done. The whole procedure to build a base image for each node of the cluster is available there: https://gitlab.com/tmorin/pine64-image-armbian
Once the base image is built, the cluster can be setup. All steps are described using Ansible playbooks. You will find all the details there: https://gitlab.com/tmorin/pine64-docker-swarm
Finally, I had to built some docker images by my-self for instance keepalived. You will find the source there: https://gitlab.com/tmorin/pine64-docker-images
Best regards
Thanks on sharing.
RE: Docker Swarm Cluster with pine64-lts and armbian build - by tllim - 11-06-2018, 10:18 PM
  which emulator is it possible to install on Pine64 Lts Paulo Capel 0 759 09-11-2022, 12:28 PM
Last Post: Paulo Capel
  really want to use lvds flat screen displays on Pine64/Sopine jjello-53 0 774 08-29-2022, 01:02 PM
Last Post: jjello-53
  Baking Pi style Course for Pine64-LTS lscdmore 1 2,566 04-30-2021, 10:31 AM
Last Post: lscdmore
  Dual cluster with video bridge. Omnios 0 3,994 01-24-2017, 11:33 AM
Last Post: Omnios
