power Circuit
#29
(07-01-2016, 08:56 AM)SkimMilk Wrote:
(07-01-2016, 07:23 AM)Topgun505 Wrote:
(06-21-2016, 12:04 PM)SkimMilk Wrote:
(06-21-2016, 11:57 AM)crash042 Wrote:
(01-31-2016, 11:49 PM)SkimMilk Wrote: Hi all,
I'm looking for the switch that tllim posted at this website:
http://sg.element14.com
I'm not electronics trained, so it's kind of hard finding it.
Can anyone advise what keyword I should be searching for?
I'm trying to find out what the pinout is, there are 4 holes, what 2 holes does the switch use.
I am not buying one of those tiny board mounted buttons.
Here's your answer: #41
Maybe this was answered elsewhere and I missed it.  But I see there are two 4-prong locations where the button provided by Pine can be plugged into.  Which set of holes does that button need to go into?
2 sets of holes for 2 functions. One is for power (pwr) while the other is reset (rst). Most people will place it on power.
Sent from my iPhone using Tapatalk
Looking at the pine64 end on, with the audio socket on the left, and the usb ports on the right, the left set of four pins are for the power switch,and right set of the pins are for the reset switch. the two connections nearest the edge of the board are the actual electrical connections for the momentary switch, and the further away connections are to mechanically anchor the right angle tactile switches.
power Circuit - by polo - 12-24-2015, 06:37 AM
RE: power Circuit - by tllim - 12-24-2015, 05:57 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 01:08 PM
RE: power Circuit - by tllim - 01-28-2016, 04:04 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 05:44 PM
RE: power Circuit - by SkimMilk - 01-28-2016, 05:56 PM
RE: power Circuit - by tllim - 01-28-2016, 07:39 PM
RE: power Circuit - by Nilocsemliw - 01-28-2016, 11:41 PM
RE: power Circuit - by Ghost - 01-29-2016, 05:55 AM
RE: power Circuit - by SkimMilk - 01-28-2016, 10:38 PM
RE: power Circuit - by Gearsoul - 01-29-2016, 01:56 AM
RE: power Circuit - by SkimMilk - 01-31-2016, 11:49 PM
RE: power Circuit - by Ghost - 02-03-2016, 06:00 PM
RE: power Circuit - by SkimMilk - 02-03-2016, 06:17 PM
RE: power Circuit - by 1q84 - 03-14-2016, 09:41 PM
RE: power Circuit - by tllim - 03-15-2016, 09:13 AM
RE: power Circuit - by 1q84 - 03-15-2016, 01:30 PM
RE: power Circuit - by tllim - 03-15-2016, 04:14 PM
RE: power Circuit - by crash042 - 06-21-2016, 11:57 AM
RE: power Circuit - by SkimMilk - 06-21-2016, 12:04 PM
RE: power Circuit - by Topgun505 - 07-01-2016, 07:23 AM
RE: power Circuit - by faddah - 04-12-2016, 02:37 PM
RE: power Circuit - by Ghost - 04-12-2016, 04:29 PM
RE: power Circuit - by faddah - 04-12-2016, 07:54 PM
RE: power Circuit - by Ghost - 04-12-2016, 08:06 PM
RE: power Circuit - by faddah - 04-13-2016, 07:51 AM
RE: power Circuit - by Ghost - 04-16-2016, 06:30 PM
power Circuit - by SkimMilk - 07-01-2016, 08:56 AM
RE: power Circuit - by pfeerick - 07-01-2016, 07:06 PM
  Z-Wave - Full and Low Power Inclusion mode B34N 1 4,269 03-26-2017, 06:03 PM
Last Post: B34N
  Power Supply for Pine a64 (2GB) Pip19083 1 4,482 01-22-2017, 01:32 PM
Last Post: Luke
  Low power headless operation? rubenk 9 15,380 01-05-2017, 12:37 AM
Last Post: swinging
  Power switch circuit drewh 43 63,591 09-19-2016, 09:17 AM
Last Post: tampadave
  Power Off / Reset Buttons - DietPi casmiguefl 4 8,331 08-12-2016, 05:28 PM
Last Post: casmiguefl
  Power over Ethernet (PoE) WLR 1 5,839 02-10-2016, 07:14 PM
  USB HDD Power eender 5 9,509 02-06-2016, 09:30 PM
Last Post: blktiger
