Installing Node.js from source on Arch Linux
Information
hi all,
so you may have run into some problems installing node.js from source with the arch linux image.
yes, i am aware you can use Arch's pacman package manager to install node.js and npm, but those tend to name them nodejs on the command line, not the standard node and then you get into a whole other how-to on fixing that. i prefer my node compiled from source and ready to go the way i expect it.
so i thought i'd put together this how-to for those who may have run into similar difficulties.
the short, tl;dr
Arch Linux has python 3.5.1 installed (at least on the image we are using for Pine64 boards). make, node.gyp and the JavaScript V8 engine depend on python 2.7.x.
so do this —
install python2 to Arch Linux using —
pacman -S python2
from the command in your home directory do:
mkdir -p ~/bin/
ln -s $(which python2) ~/bin/python
export PATH=~/bin/:$PATH
...then, switch to the directory where you've downloaded and decompressed the node.js source and do —
cd /path/to/where/your/node.js-source-is/
./configure
make
sudo make install
voila! you got node! test it out with —
node -v
npm -v
...and — profit!  ? ? ?
the long version
for background, check out this node.js issue on github, #2735, as well as the issue they all point to and reference, #418, as well as the issue i filed, #6249.
basically, it comes down to this — Arch Linux installs only Python v3.5.1, and the JavaScript V8 engine (maintained by Google's The Chromium Project), as well as Node.js' node.gyp and the script files for the build all want to use Python 2.7.x. If you go into script files for the node install like the configure file, you'll see that at top, it says —
#!/usr/bin/env python
now you could use Arch Linux's pacman (similar to deb repositories and apt in Ubuntu and rpm in RedHat) package installer to install Python 2.7.x change this to —
Quote:#!/usr/bin/env python2
...and that would work for a bit with the configure file, but would fail the moment anything is required of node.gyp or the V8 engine, as they have hard coded stuff in them for python which defaults to the OS' python default install, which in Arch Linux is Python 3.5.1.
so over that issue for node.js, @rvagg suggests the following —
  • install Python 2.7.x to your Arch Linux install using the pacman package manager —
pacman -S python2
tar xvf node-vX.X.X-tar.xz
     this will create a node source install directory in your Downloads folder. you can go ahead and delete the compressed node.js source file now.
  • switch to your home directory
cd ~
  • run the following in the command line —
mkdir -p ~/bin/
     this creates a directory under your home directory that is "bin," you create a symbolic link from there to your python2 for installing, then you export that to your $PATH statement.
  • now switch back to the directory that has your node.js source install, and run the following —
./configure
make
sudo make install
     ... and voila, you got node!
  • now test it out using —
node -v
npm -v
     ...which should return, now, both the version numbers for node.js and npm.
best,
—  faddah
     portland, oregon, u.s.a.
Installing Node.js from source on Arch Linux - by faddah - 04-16-2016, 11:05 PM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 673 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  Irradium (based on crux linux) riscv64, aarch64 mara 0 641 11-03-2023, 03:10 PM
Question Issue installing New OS Using SD Rudy558 2 3,658 06-29-2021, 03:37 AM
Last Post: TfromTexas
  Linux Headers jedichewbacca 5 8,663 02-28-2018, 10:35 PM
Last Post: evilbunny
  Mini-Tutorial to get a linux Desktop GUI working on Pine64+ speedro86 15 26,646 04-05-2017, 01:45 PM
Last Post: speedro86
  Arch Default Login, no luck. JzJad 1 4,118 02-01-2017, 10:27 PM
  Linux laptop rusty377 2 4,316 11-27-2016, 08:52 PM
Last Post: pfeerick
  Install node.js on Ubuntu (via npm) Zhara 5 9,771 08-22-2016, 09:02 AM
Last Post: Zhara
  Installing remix os fooclueshoedo 3 5,262 07-07-2016, 06:33 PM
Last Post: fooclueshoedo
Bug ETA for solution for DMA problem for Arch Linux image & A64+ 2 GB boards? faddah 16 21,475 04-19-2016, 09:09 PM
Last Post: patrickhwood
