Rock64 Login
Bug
Hi everyone!Nice to meet you.
I have a Rock64 v2.0, 20170713
I installed:
Armbian_5.59_Rock64_Debian_stretch_default_4.4.152_desktop.img using the Etcher flasher on microSD.
The first time I insert the flashed microSD card into the Rock64 i eventually get a login prompt asking for user.
I write in user: root and press enter.
There is now no response or it hangs for a long time and I don't get the password prompt. Sad
Then I press reset on the Rock64 board and after a while i do get some text on the screen, mainly hexadecimals and addresses cycling through, then the screen goes black. This goes on an infinite repeat loop.
I have a keyboard and mouse plugged in and wired Ethernet.
Does anyone have this or am I approaching this the wrong way? Confused
Many thanks,
luke
Rock64 Login - by lpninja - 10-01-2018, 10:24 PM
RE: Rock64 Login - by tllim - 10-04-2018, 12:02 AM
  MRAA Rock64 support jbize 2 2,572 07-09-2022, 04:40 AM
Last Post: igorp
  Rock64 with Debian netinst usb Bloris 6 9,116 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 4,389 06-12-2019, 10:44 PM
Last Post: evilbunny
  Custom Kernel for ROCK64 mayst 2 5,050 01-07-2019, 08:04 AM
Last Post: mayst
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,474 06-26-2018, 11:37 AM
Last Post: Luke
  Will the Rock64 work as a mobile data storage device? Kennetht 1 3,173 03-29-2018, 10:07 AM
Last Post: xalius
  Laptop as a bridge for Rock64's internet connection dmitrymyadzelets 3 5,386 03-28-2018, 05:24 AM
Last Post: dmitrymyadzelets
  Rock64 OS eMMC boot ProfessionalDreamer 2 5,506 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
  opencv on rock64 bendiro 4 7,213 02-07-2018, 05:08 AM
Last Post: xalius
  Kodi on Rock64 board cenguix 2 8,865 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
