Creating bootable Debian backup image
(12-11-2018, 02:14 PM)semeral Wrote:
(08-31-2018, 05:37 PM)evilbunny Wrote:
(08-31-2018, 03:01 PM)Drago Wrote: Hi all,
I'd like to periodically create backup images of Debian (stretch-minimal-rockpro64-0.7.9-1067) because I end up breaking my system a lot (I am a brand new to Linux). How would I go about doing this? Could I take an image of my microSD while it's connected to my macbook pro, or do I have to do this from the Debian command line?
-D
If you want offline backups you can just use dd to clone the image, if you want backups while it's running you'll need something like rsnapshot which can take incremental backups.
I'm booting from eMMC, so while using dd backup, do I do just dd if=/dev/mmcblk1 [...] or should I also backup /dev/mmcblk1boot0 and /dev/mmcblk1boot1?
You only need to dd the device. That will backup everything including the partition table.
Creating bootable Debian backup image - by Drago - 08-31-2018, 03:01 PM
RE: Creating bootable Debian backup image - by evilbunny - 12-11-2018, 03:42 PM
  PBP Debian 11 GRUB install error zlth 2 1,902 11-18-2022, 07:42 AM
Last Post: zlth
  Soquartz - what image for Model A baseboard? kbanfield 0 1,450 10-14-2022, 10:38 AM
Last Post: kbanfield
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 150,370 01-15-2020, 12:46 PM
  Rock64 with Debian netinst usb Bloris 6 9,051 12-03-2019, 12:37 PM
Last Post: madalin
Information Creating a NAS server in Pine64 javi_cala 4 8,306 01-21-2019, 02:03 AM
Last Post: bartes
  The Debian Jessie User Accounts? jesse1234 6 7,698 01-20-2019, 06:07 PM
Last Post: zer0sig
  7" Screen - Does it work with Debian abasel 1 3,880 07-26-2017, 05:44 AM
Last Post: pfeerick
  Boots just fine. Can not install new image. willpine 5 7,540 07-25-2017, 06:39 AM
Last Post: willpine
  unable to write an pine64 image on a 16G micro suresh 2 5,369 01-26-2017, 12:56 PM
Last Post: suresh
  Need support for Database use in debian jessie other than mysql sarav_sara 4 6,083 01-16-2017, 06:23 AM
Last Post: Luke
