Regular Android build for Rock64?
Question
Dear Pine64 team! Why don't you make a regular Android build for Rock64? The TV UI in the stock OS is almost unusable with touchscreens. No navbar and status bar so it is very inconvenient to connect to network or adjust the volume. I just don't get it. Are there any TECHNICAL limitations for rk3328 for making a regular android os? Rock64 is a really great product and has a great hardware but the software side is a lot of pain
Regular Android build for Rock64? - by fender90 - 08-18-2018, 06:53 AM
RE: Regular Android build for Rock64? - by tllim - 08-24-2018, 03:35 PM
RE: Regular Android build for Rock64? - by Pepe - 11-02-2018, 05:49 PM
RE: Regular Android build for Rock64? - by dudemo - 08-29-2018, 02:52 PM
RE: Regular Android build for Rock64? - by dudemo - 08-31-2018, 07:01 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,267 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,028 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,554 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,541 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,018 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,502 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,016 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,577 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,725 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,796 09-09-2020, 08:44 AM
Last Post: BowerR64
