SATA?
(12-28-2015, 10:01 AM)Groupers Wrote: According to the datasheet, the SoC has eight DMA channels.
Great. And if the SoC would also include a SATA controller (c'mon: if you already had a look into the datasheet then it's easy to search for 'SATA' there) then this would be a good candidate to use DMA instead of PIO. But since there's no SATA controller and no other highspeed bus like PCIe there's no SATA.
The best choice is a good USB-to-SATA bridge and this won't exceed 35MB/s under best conditions. If maybe 2017 mainline kernel support for the A64 is ready this might increase up to 40 MB/s: http://linux-sunxi.org/USB/UAS
But again: No real SATA and just one single USB 2.0 host port on the A64. Therefore not that much I/O bandwidth available.
SATA? - by Groupers - 12-22-2015, 09:02 AM
RE: SATA? - by tkaiser - 12-22-2015, 10:33 AM
RE: SATA? - by hazerty - 12-22-2015, 11:59 AM
RE: SATA? - by tkaiser - 12-22-2015, 01:09 PM
RE: SATA? - by Groupers - 12-28-2015, 10:01 AM
RE: SATA? - by tkaiser - 12-30-2015, 05:28 AM
RE: SATA? - by Groupers - 01-07-2016, 06:12 PM
RE: SATA? - by Ketsa - 01-11-2016, 02:00 PM
RE: SATA? - by tllim - 01-11-2016, 02:26 PM
RE: SATA? - by Galileo - 01-11-2016, 03:00 PM
RE: SATA? - by tllim - 01-11-2016, 03:10 PM
RE: SATA? - by hlide - 01-11-2016, 03:07 PM
RE: SATA? - by Galileo - 01-11-2016, 03:24 PM
RE: SATA? - by Groupers - 01-18-2016, 05:32 AM
RE: SATA? - by Groupers - 01-20-2016, 06:47 AM
RE: SATA? - by simonritchie - 06-16-2016, 07:37 AM
RE: SATA? - by lenny.raposo-pine64.pro - 06-16-2016, 08:15 AM
RE: SATA? - by simonritchie - 06-20-2016, 11:32 AM
RE: SATA? - by ssvb - 06-20-2016, 12:04 PM
RE: SATA? - by skenn_ie - 01-04-2017, 09:51 AM
RE: SATA? - by CaptainZalo - 01-10-2017, 05:55 AM
RE: SATA? - by tllim - 01-10-2017, 08:19 PM
SATA support - by Yupnim - 01-20-2016, 10:45 AM
RE: SATA support - by tllim - 01-20-2016, 10:51 AM
