Android Oreo 8.1 source code
(12-02-2018, 07:37 AM)frankwz Wrote:
(08-08-2018, 12:45 AM)tllim Wrote:
(08-07-2018, 12:59 AM)shinymetal Wrote: Hi all,
after successful download and compile, I'm facing to the problem of writing an SD card with the Android 8 Image for my Rock64 board.
Is there a script to do the task?
Anybody knows where to get info about partitioning and writing image to the SD card?
I tried Etcher, but I have no output on the console.
Although, the stock image runs fine, so seems to me definitely a partitioning problems...
Any help?
You may need the ROCKChip SD firmware tool, and I just attached on this post.
ROCKChip SD firmware tool format sd update format not work,i want to know how to create a raw img for boot from sd card,could you give me some help thank you very much
Did you figure out how to create the raw image after building the android rom?
Android Oreo 8.1 source code - by shinymetal - 08-07-2018, 12:59 AM
RE: Android Oreo 8.1 source code - by tllim - 08-08-2018, 12:45 AM
RE: Android Oreo 8.1 source code - by frankwz - 12-02-2018, 07:37 AM
RE: Android Oreo 8.1 source code - by dazza5000 - 07-18-2019, 01:37 PM
RE: Android Oreo 8.1 source code - by shinymetal - 08-08-2018, 06:29 AM
RE: Android Oreo 8.1 source code - by burram - 08-31-2018, 05:56 AM
RE: Android Oreo 8.1 source code - by ma_f66 - 09-01-2018, 04:30 AM
RE: Android Oreo 8.1 source code - by shinymetal - 09-10-2018, 03:47 AM
RE: Android Oreo 8.1 source code - by Dasone77 - 12-31-2018, 08:02 AM
RE: Android Oreo 8.1 source code - by Blinky - 02-09-2019, 01:21 PM
RE: Android Oreo 8.1 source code - by shripal17 - 02-13-2019, 09:46 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,219 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,007 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,533 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,163 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 3,998 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,479 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 5,980 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,564 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,700 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,750 09-09-2020, 08:44 AM
Last Post: BowerR64
