SD Card locked
(06-07-2018, 09:09 PM)icemeister Wrote: I was using Etcher to load other distros to Sd card. Side of adapter not locked. Formating in windows says write protected still trying to load files and it fails in Etcher. Did compleat one card but it failed to load in pinebook. It looks like Etcher locks the card once written.
Let me know if i can give any more info, i am a noob to this
That it happened using Etcher is coincidental, because I can assure you Etcher does not 'lock' the card once written. It is possible you have a faulty microSD card, as write protection and write failure errors are common when they have failed and can no longer been written to.
Since you're on windows...
Try using rufus (https://rufus.akeo.ie/) to format the drive, and see if you can reset it back to it's full size.
Then try running h2testw (http://www.softpedia.com/get/System/Syst...estw.shtml) in order to see if the microSD is working properly.
You can also try the other tools listed here (https://www.raymond.cc/blog/test-and-det...h-h2testw/), but if rufus and h2test2w don't work, it doesn't sound good.
SD Card locked - by icemeister - 06-07-2018, 07:21 PM
RE: SD Card locked - by pfeerick - 06-07-2018, 08:04 PM
RE: SD Card locked - by icemeister - 06-07-2018, 09:09 PM
RE: SD Card locked - by pfeerick - 06-07-2018, 09:30 PM
RE: SD Card locked - by icemeister - 06-07-2018, 09:48 PM
RE: SD Card locked - by alexenwaston - 05-13-2020, 11:59 PM
  install iso from sd card to emmc aular 2 171 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 791 01-09-2024, 07:02 PM
Last Post: britelite
  SD Card has wrong capacity AndyM 11 2,127 06-11-2023, 12:30 AM
Last Post: AndyM
  locked out on PIN screen g40 1 594 06-07-2023, 10:20 PM
  Device Unable To Read MicroSD Card _radv_ 19 5,683 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,364 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 1,871 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,306 11-23-2022, 05:19 AM
Last Post: _radv_
  SIM Card Install pineme 4 4,993 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  SIM card slot not working dekrets 2 2,099 02-12-2022, 11:09 AM
Last Post: dekrets
