4.4.120-gac51b70a-dirty works, 4.4.126-g6dc34509-dirty seems broken
I dare not do apt update/upgrade on my rock64-NAS, my family is using it.  So, I intend to build an update with AppArmor enabled on my spare rock64 and swap the sdcard after test.
Today, I follow exactly the same steps as what I had done successfully before.  But failed.
Sorry I am not a developer, I don't even have an active git a/c, I am happy to follow if you have a comprehensive instruction know-how on how to report error.  However, obviously, you don't have time to prepare that.  I can only report it here.
Running the first make -j5 (after make menuconfig) looks fine.  --edit-- sorry, it gets error too.
Then, there are lot of errors (missing files) during sudo make modules_install
Followings are copied from the end of sudo make install
I did it twice.  It should easily be reproduced.
make[3]: *** [drivers/gpu/arm/built-in.o] Error 1
scripts/Makefile.build:484: recipe for target 'drivers/gpu/arm' failed
make[2]: *** [drivers/gpu/arm] Error 2
scripts/Makefile.build:484: recipe for target 'drivers/gpu' failed
make[1]: *** [drivers/gpu] Error 2
make[1]: *** Waiting for unfinished jobs....
  CC      drivers/hid/hid-debug.o
  CC      drivers/hid/hidraw.o
  LD      drivers/hid/usbhid/built-in.o
  LD      drivers/hid/built-in.o
Makefile:1028: recipe for target 'drivers' failed
make: *** [drivers] Error 2
Thank you for your attention.
edit --------------------
BTW, I always use
$ git clone --depth 1 --single-branch -b release-4.4 https://github.com/ayufan-rock64/linux-kernel
to get the source code and assume it is the stable release.  Is it?
edit 2 ---------------
Lucky me saved a copy of source code for 4.4.120
Just do the "make -j5" again, I timed it and it took real 80m.
I amended the first post that said the step of "make -j5" is fine because that took real 40m only.  Something should be wrong for such a big time saving, right?
Good Night
4.4.120-gac51b70a-dirty works, 4.4.126-g6dc34509-dirty seems broken - by cooker - 05-07-2018, 08:54 AM
Sad Is there a none-headless Linux OS that really works now for Rock64? AkiraSensei 7 9,393 07-09-2020, 10:02 PM
Last Post: nethammer
  apt --fix-broken install KC7NOA 1 2,692 10-29-2018, 09:17 PM
Last Post: KC7NOA
  ROCK64 works for me rabinnh 2 3,297 02-11-2018, 05:22 PM
Last Post: jebivetar
  Broken yellow Ethernet light? jl_678 1 2,887 08-27-2017, 04:23 PM
Last Post: MarkHaysHarris777
