Installing Android on SD Card
(06-24-2018, 07:48 PM)dshookowsky Wrote: Yeah, I'm in the same boat.  Saw some press on the board and thought it'd be great, but I was only able to get it to boot android once and when I hooked it up to the TV, the audio was crap.  Now I can't even get that.
Would like an Android TV device that doesn't suck - I've tried the MK808 (Wifi never worked), MiBox (netflix stopped working after a week), and this with no luck.
I haven't used the android build in a while, but with any SBC the most common pitfalls are dodgy power supply or crap microSD card. If you're using the stock power supply that shouldn't be an issue. And I would strongly recommend you try using a Samsung EVO card if you aren't already. Your existing card might be good for phones, cameras, etc, and even claim higher performance specs than the Samsung EVO series, but the card brand/type DOES matter, and is critical with Android as it is heavy on SD card usage. I didn't have any issues with my rock64s when I was trying some of the Android builds before. There has also just been a release of a Android 8.1 for the rock64 that might be worth trying
Installing Android on SD Card - by Phingum - 03-14-2018, 11:15 AM
RE: Installing Android on SD Card - by gorba77 - 03-14-2018, 01:04 PM
RE: Installing Android on SD Card - by Phingum - 03-14-2018, 01:12 PM
RE: Installing Android on SD Card - by marlab - 06-06-2018, 02:04 PM
RE: Installing Android on SD Card - by pfeerick - 06-25-2018, 02:47 AM
RE: Installing Android on SD Card - by Luke - 03-14-2018, 01:38 PM
RE: Installing Android on SD Card - by Phingum - 03-14-2018, 01:54 PM
RE: Installing Android on SD Card - by gorba77 - 03-14-2018, 03:14 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,268 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,029 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,556 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 168,550 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,019 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,502 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,017 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,577 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,725 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,799 09-09-2020, 08:44 AM
Last Post: BowerR64
