01-30-2018, 12:17 PM
Hi, there is no standard for eMMC connectors, since those get usually soldered directly on boards. So you usually have to get one that matches the modules you buy... the Pine64 modules use the same connector as the ODROID modules though... the one you bought is used to solder a eMMC on the backside...
Come have a chat in the Pine IRC channel >>
